Question about Sanyo Vpc T1496 14.0 Mp Digital Camera - Red
My sanyo VPC-T1496 won't turn on properly. The lense opens and then immediately closes and is unusable.
When I turn my digital camera on the lense opens, makes a noise, and then automatically closes. It is stuck with a closed lense, but the green light is on.
night71
  • 328 Answers
SOURCE: my sanyo vpc-c5 digital camera won't turn on
If you already tried a new battery, I would suggest cleaning the battery terminals with alcohols and a q-tip first and check for loose terminals. It may be a power switch which unfortunately can't be changed or fixed by the average user. If you want to trouble shoot further and feel you can do it yourself, I will send you links on repair. Otherwise it should be brought in to a reputable repair shop.
Posted on Nov 17, 2007
leecom72
  • 4806 Answers
SOURCE: Need users manualnfor sanyo VPC-T700 digital
Get the manual here >>>>>>>>
http://sanyoservice.com/pdf/images/VPC-T700.pdf
This manual will show as an on-line PDF, when its loaded up all you have to do is save it to your computer.
Regards
Posted on Jun 19, 2009
  • 11967 Answers
SOURCE: My camera will not retract its lense and now I can't use it
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 26, 2009
Testimonial: "thank u!!!! this i tried all the methods in order and i finally tried fix#7 and it worked! i think i hav sand in my camera from a vacation"
  • 3 Answers
SOURCE: Sanyo Xacti VPC-E1W dispay is black, no image
Is the camera on and does it have batteris fully or half way charged?
Posted on Apr 09, 2010
fikretunalir
  • 238 Answers
SOURCE: I need a manual for digital movie camera/sanyo
This is your manual.
Sanyo VPC-HD1AEX VPC-HD1
https://dmc.wisc.edu/images/EFLmanuals/sanyo_xacti_vpc-hd1a.pdf
You can download it from above link.
Regards.
Sanyo vpc t1496
To turn on your flask, simply press the symbol that looks like a lightening bolt. Located on the rear of the camera, it is to the right of your screen, on the jog dial that surrounds the 'set' button', on the right.
Hope this helped.
Dec 06, 2013 | Cameras
Need the manual for Sanyo digital camera model VPC-T1496
You may download a copy of the manual here.
Mar 01, 2013 | Cameras
The button that takes the actual picture and zooms in and out broke off. It's on my Sanyo VPC--T1496 R
call (800) 421-5013 for sanyo repairvisit link at bottom of page to find a service centerrepair yourself, find a broken device exactly the same as yours that has this button in tact, extract and replace, take to you local electronic repair shopit is not cost effective to repair device in the amount exceeding total cost of 20$usd how ever there are several cost effective ways to repair this device if you or a friend are a little "tech savvy"--Good Luck.http://www.pstc.panasonic.com/WhereTo/FindServicer.asp?ValidJS=1&Pass=1
Jan 27, 2013 | Cameras
My camer will power up say battery low but shows to be full but goes off and will not come on and charge.
How old is the battery? Batteries do die with with time. Be sure to replace it with a manufactures battery, not an aftermarket one.
Nov 14, 2012 | Sanyo Vpc-t1496 14 Mp Digital Camera - Red
Can't up load pics to computer~~keeps blacking out sanyo 12.1 vpc~s120
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 07, 2012 | Sanyo Vpc S120 12.1 Mp Digital Camera -...
Lense won't come out
Check to make sure the batteries are okay,and what mode your in because some modes will not allow the camera lens to come out
May 05, 2012 | Sanyo VPC-S120 Digital Camera
My sanyo VPC-E760 CAMERA IS SHOWING LENS ERROR 27....THE LENSE WILL NOT GO BACK IN...
Dear sir,
this happens when the clearance for the lense mechanism to open and close is being insufficient due to -small bits of sand or lint that may become get trapped in the mechanism which is commom while taking photos in open dust spaces.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned,if delayed the problem gets complicated
thnk you..take care
Oct 08, 2010 | Sanyo VPC-E760 Digital Camera
Lens will not retract on Sanyo VPC-T850, 8.1 megapixel, digital
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
Jun 10, 2009 | Sanyo VPC-S880 Digital Camera
Sanyo Vpc T1496 14.0 Mp Digital Camera - Red Logo
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
