I have a swann dvr security camara set but I seem to not be able to get it to start recording It display the letter H on camara 1 I have it all set up and in place I don't know how to make it start re
    New Friend:
H means the system is not detecting the hard drive check connections to ha and try again if dosent work remove hd test it and try agian
Posted on Dec 28, 2012
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I changed my hard drive
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jun 15, 2011
Is Swann PRO-1080FLD camera compatible with my TECHview 8 CH AHD 720P DVR Model No QV - 3147 DVR. Compatible Recorders: DVR-4575, DVR-4580
No its not. You might get it display an image but will probably be black and white as the resolution on the cam is higher than the supported resolution on the dvr
Dec 13, 2017 | SWANN Home Security
Have a swann DVR 4_950. Let's u set up to record. Shows the motion sensor icon and says it set to record. But when I went to watch it. It said empty HDD. Anyone know what to do.
Go into your Record Menu then Record Schedule and make sure you have green set for recording motion. Other thing to check is record speed to make sure the frames per second are set. If the record icon shows up next to the motion icon then you may have a hard drive issue. Try to reformat
Dec 03, 2017 | SWANN Home Security
I bought a Swann Digital & Recorder today it wont record and no picture
You got to change the input of the camara to d1 also check you monitor out are you using hdmi if so lower the aspect ratios also you need to check that you have selected record in your settings motion or on full
Feb 19, 2017 | SWANN Home Security
I have a swann view security system ,,and something not working cause it only says mode not supported ,,,,, how do you fix this
Have you tried a hammer? Kidding!!! Usually this is a conflict in resolution between the DVR and the TV. You may need to lower the resolution of the TV for the particular input you are using. You may have a 1080P TV and a 720P DVR. Once they match, the issue should be resolved.
Aug 30, 2015 | SWANN Pro-Series DVR-4200 4-Channel...
My system has quit recording and says anolog 1 full
The unit is probably not set to over write. If this is the case make sure you set the unit to ver write or it will quit record when the hard drive is full.
Aug 26, 2014 | Swann Communications Swann Alpha D02C5...
After rebooting swann security how do you get it to start recording? When you push replay it says no files
Make sure that the DVR hard drive is not defective, if it is in working order go to schedule recording and select your recording based on motion, alarm or continous
May 25, 2014 | SWANN Home Security
What is the format for the DVR-415 time set?
You will need to connect to a PC, then open the notepad file and change the time carefully. Safe the notepad file and the correct date and time should be set.
May 07, 2014 | SWANN DVR-415 ThumbCam Mini Digital Video...
How to factory reset swann dvr4200
You need to contact the seller. SWANN does not make their own DVRs and it could be a variety of manufacturers who all have different reset methods.
Mar 10, 2014 | SWANN Pro-Series DVR-4200 4-Channel...
Motion recording for Swann dvr4
Have you switched cameras to AUTO (A) on settings line. Is the sensitivity for motion turned on and set correctly =
1= very sensitive 9 = less sensitive.
Setting areas are shaded = no recording area
unshaded = recording area
Hope this helps - good luck.
Mar 14, 2008 | Swann Communications DVR4-Alert Video...
Computers & Internet Logo
260 people viewed this question
David Payne
David Payne
