Question about GPS
How do I install this on my boat witch wires go where?
    Problem Solver:
  • 10 Answers
Throw it away... it will cost more to get what you need then to buy a new one ready to go.
Posted on Dec 04, 2012
Witch model of boat do i have with ser no LAR75995H405
Sounds like a 2005 Larson. All boat manufacturers go by the last two digits to identify the year. The 180 or 186 is the model number which normally corresponds to the boat length: 186 meaning 18'6" and 180 meaning 18 feet.
Dec 23, 2014 | Boating
Caravelle boat wiring schematic
I doubt that you'll find one. For the engine package (harness) you'll be able to find a diagram in the applicable service manual or on line. As far as the wiring that Caravelle installed in your boat good luck. My advise is to look at Nigel Calders book " Boat owners Mechanical and Electrical Manual". Charlie Wing also wrote a good text. Unless it's been changed by some previous owner your boat's wiring will be color coded in line with the standards of the ABYC. Once you know the color code it's fairly simple to figure out the wiring. At about 12 years your boat is prime for a few electrical issues.
Jul 27, 2012 | Boating
Install horn on boat
check the ground wire, make sure it is not just wired to a screw in fiberglass. also need to wire it from fuse panel.
Jan 25, 2012 | Volkswagen Cars & Trucks
I have changed my boat and have kept the ST2000 and S100 remote and the wireless base to fit on my new boat. Is it possible to get a wiring diagram to fit this to my new boat please
HI!
We have the same setup on our vessel.
Here's the link from Raymarine for instructions to install your base unit: http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=1020&PRODUCT=3036
(Click on Base Station & Controller installation)
And here is the link to your owners manual for your ST2000+:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=87&PRODUCT=19
(Click on 81130 6.pdf)
These contain all the wiring information you need to get it done!
Happy Boating!
Jan 24, 2011 | Raymarine ST2000 Plus Tiller Pilot A12005
Where can I find a wiring diagram to install a generator into a boat? I know how to wite the 110 volt side but where do I connect the 12 volt power from the generator into the 12 volt distribution panel?
Installing a generator into a boat is critical to be done correctly. You need to contact the manufacturer of your generator for approval, and wiring diagrams. If done incorrectly (which if you are connecting 12v from gen), you may create eddy fields that can cause galvanic corrosion, not to mention electrical shock hazards.
If your generator isn't marine rated, then don't install it into a boat.
Portable generators can be used, but don't hardwire those into a boat. Just use extension cords to the appliances you want to power.
Nov 22, 2009 | Northern Tool Electrical Supplies
REPLACMET STARTER SWITCH IN 2007 TRACKER-GRIZZLY BOAT NO WORK
the wires may be correct you need to make sure all the fuses are good they will be held in little rubber black cylinders on the engines they will be long glass fuses if any possitve touched a ground it would have blown a fuse so check them first then make sure when you push your choke it is working have someone stand by the motor to make sure i belive that is what the blue wire is to there may be a fuse by the battery as well the solid red is your power supply look at your starter solenoid and see what wire is your acc. wire as well but the blue wire should be a hot for something and i need to know what the wire colors are from the harness if there all the same but the blue
Jul 05, 2009 | Boating
Need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Mar 15, 2009 | Boating
GPS Logo
22 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
