I need the screw size for a Memorex MLT3221 tv base. I got the tv used but no screws to attach the base.
  • mari v Dec 03, 2012
    I figured it out. Used four Hillman brand machine screws, Oval Head Phillips size M5-.80 x 25 purchased at my local Lowes. Hope this helps others.
    By the way, these are metric sized screws
onyeobike
  • 70 Answers
SOURCE: screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
Posted on May 25, 2009
ldaala
  • 65 Answers
SOURCE: need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Posted on May 26, 2009
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
SOURCE: need to know what size screws go in to the tv base
I ended up having to take my entire tv into Home Depot. This is what the package says on the screws that worked:
"Machine Screw Pan-Slotted 4mm- & X 20mm Stainless Steel BR-B/ 12-B/322"
I know this is an old post but since I couldn't find any answers when I was looking I wanted to help someone else out.
Posted on Apr 01, 2010
  • 87 Answers
SOURCE: I lost the screws for the base mount for a vizio
Local ACE Hardware, take one for sample
Posted on May 13, 2010
How to find replacement parts for my television base
For 22" or 19" Emerson TV base 3 screws (M4 x 12)
Emerson LC190EM2 User Manual Supplied Accessories Symbols Used In This...
this size may differ for your TV based on its size and quantity may differ based on the design / model of your TV.
could have helped if you mentioned the model number as well.
May 26, 2016 | Emerson Televison & Video
What size of screws/bolts do I need to mount the base to the TV?
It uses metric machine screws. You may have to spend some time at your local "big box" store searching for the right hardware, BUT length is important from a safety perspective. Insert a toothpick in one of the holes and mark where it is flush at the top. Take your toothpick to the store and match length with the M4, M6, etc. screws you will be sorting through.
A large screen TV such as yours requires two people to place it screen down on a soft surface such as a blanket for hardware installation. Be sure to tighten the screws firmly. Enlist the same two people (or designated alternates) to lift the TV and place it where it should be located.
Sep 05, 2015 | Westinghouse Televison & Video
Sansui 19" LCD tv stand screw size
Go hardware shopping for the metric screws you need. They have an Mx designator
Feb 18, 2013 | Sansui 19 in. LCD TV
What size screws do I need to attach the base to my tv
U are going to required 3.6 mm screw size...enjoy quality tv experience..
THANK U
Nov 23, 2012 | Televison & Video
Olevia 532 base stand screw
hi, did you find your answer? I have the same problem. eointosullivan@gamil.com
Jun 27, 2012 | Syntax Olevia 532H 32 in. LCD HDTV
Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Jul 29, 2010 | Memorex MLT3221 32 in. LCD TV
How do you reste all inputs on the mlt3221. I lost the remote and all inputs are locked
Check your manual for a reset option, but you can press MENU on the side of the television, and you will have to navigate up and down the menu items by using the VOLUME buttons for going up and down, and the CHANNEL buttons for going in and out of your menu selections. There is a manual available @ http://memorex.com/downloads/manuals/MLT3221-BLK_QSG_manual.pdf. Hope this helps!
Aug 07, 2009 | Memorex MLT3221 32 in. LCD TV
I hooked up my computer,I get a picture but no sound come's from the T.V.? Thank You.
You need to attach your sound card to some sort of audio device... speakers, a receiver attached to speakers, or the audio input on your TV. The connection you are currently using sounds like a video only connection.
Jul 13, 2009 | Memorex MLT3221 32 in. LCD TV
Taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Apr 08, 2009 | Televison & Video
Owners manual
Here's a link to the manual on Memorex's site so you can download a copy:
http://www.memorex.com/downloads/manuals/MLT3221-BLK_QSG_manual.pdf
And here's an online vendor offering the remote you need:
http://www.newremotecontrol.com/Mfrs/Memorex/Memorex/845-042-GT1TAHBH.htm
If you've found this useful please take a moment to rate the solution. Thanks for asking here!
Dec 07, 2008 | Memorex MLT3221 32 in. LCD TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
