Question about Little Tikes Cozy Coupe
Front wheels stiff on little tikes coupe
After fixing together the little tikes car, one of the front wheels is stiff and drags along horizontally rather than turning freely with movement of the vehicle. Any advice?
4 Suggested Answers
Blackberry_U
  • 223 Answers
SOURCE: little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Posted on Jun 15, 2009
pamelakeenan
  • 33 Answers
SOURCE: I am trying to take the front wheels of a Step 2 fire truck
push them side to side as they may have we sides that lock. try diff positions when turning the wheel
Posted on Sep 29, 2009
slave2aslave
  • 302 Answers
SOURCE: Little Tikes replacement wheels
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=3564&#
This should help.
Posted on Oct 04, 2009
Power steering
Before changing pump jack car up check track control arms & bearings.Sounds like iits dragging not turning.Chech all movement will wheels off the deck ie on ramp.my poblem was dirt& locked control arm.
Nov 17, 2013 | 2007 Mercedes-Benz GL450
Front Wheel
yes you can if you don't want to pay for it you can use kid's cribe that have simuler wheel or you can past it by melting plastick into it thank you .
Jun 11, 2013 | Little Tikes Cozy Coupe
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Dec 04, 2012 | Little Tikes Cozy Coupe
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
Need replacement decals: Little Tikes Van & older Cozy Coupe.
i have seen a few replacement stickers for such items on Ebay.
Apr 19, 2010 | Little Tikes Swing Along Castle
Just ranover wheel on Little Tykes 3 in 1 Smart Trike
I just did the same thing.. were you able to get a replacement wheel?
Mar 21, 2010 | Little Tikes Swing Along Castle
Last time same wheels I bought it from amazon. take a look here Kids Tell All Hear about their favorite new toys I hope this was helpful. cheers
Oct 04, 2009 | Little Tikes Cozy Coupe
Little Tikes Cozy Coupe Logo
526 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
