Question about Nikon Super Coolscan 5000 ED Film Scanner
Vertical banding Scanner works fine with film strips, but has vertical banding when scanning mounted slides. No banding if scanned matte side up. Nikon says send in for repair but its out of warranty and works with film strips. Suggestion?
  • 3 more comments
  • Harryar Mar 29, 2008
    I have just (7 days ago) bought a new Nikon Super Coolscan 5000 and I went to the shop to pick it up to avoid transportation. However after the first 40 odd kodachrome slides at various settings which were OK, I now get the verticle banding, initially on single scan, but now also on multi-sampling. It surely can't be the machine and this problem appears common on other forums, so their must be a logical solution. What is it Nikon?? Oh yes, I am using Nikon Scan 4.02 and have tried various ages of slides from my collection and am about to install the negatives scanner insert into it, to see if there is a similar problem with colour negatives, but from other forums it appears to be framed slides only that have this problem.
  • wjwalrus Jul 08, 2008
    Mine is brand new, just out of box and is showing vertical banding (closely spaced vertical black lines) on the entire frame. It always occurs at default resolution (4000 px/in) but not at low resolution, such as below 2000 px/in. When the banding occurs, it makes the entire frame appear very dark due to all the black lines. When you zoom all the way in, you can clearly see why. I've been scanning only mounted Kodachrome 64 (daylight) slides. I was a little surprised by Nikon's response after I sent them my scanned samples - they asked me to try multi-scan mode, and to look for defects in the slide by using a magnifier (the slides look fantastic under a microscope). There is no difference at all when doing multi-scan (all the way up to 16x). I also get an error message at every startup that says I need to remove the slide tray, then it says that auto focus is not working. I have my RA number to return it, but now I wonder if the next one will have the same problems.
  • magbjo Sep 26, 2008
    I have the same banding problem. Is there any fix for it or do I have to send it in for repair?
  • Peter219 Oct 31, 2008
    Exactly the same, brand new Coolscan 5000, every other horizontal pixel is not scanned and remains black so that at 1600% zoom it gives vertical black lines over the entire scan.
    Also the same initial nonsense about removing the slide tray and not being able to focus. 4.02 update to software and no firmware updates are available.
    Nikon tech support are worse than useless and don't even have access to their own databases...maybe you don't have enough memory, perhaps the CPU is choking....... (I have a dual processor and 2gb memory)
    How did others resolve this problem? Did a replacement scanner solve the problem?
  • nikond2x Jan 12, 2009
    Exactly the same problem. I tried different softwares, and found that vertical banding disappears vith Vuesscan, but remains with Silverfast. So it must be a Nikon driver problem, as Silverfast uses Nijon driver library.
  • 3 Answers
Well not a complete solution but. . . It will help. 1st Digital Ice will screw up when trying to use it's infrared on Kodakrome so either don't use it or better yet don't use Nikons scanner utils. I use both Silverfast and Vuescan and will never look back yes they both solved this but the real issue is inside but do download a trial of vuescan before you go any further.
Your problem might be a cleaning of the mirror since mounted slides might "curve" in the frame differently and accentuate this issue. Look at this site I clean mine once every 6000 scans which works out to about once or twice a month.
I also recommend (a must do) is run your scanner on its side if you own a sf-210 feeder you already are so look at how this unit attaches on nikon's site or in your manual and do it. This way the guts are on their side (mirror not lying almost flat for all the dust to fall onto it).
Good Luck Morphoto.ca
Posted on Nov 14, 2008
  • 35 Answers
You must have to send it for repair. You will be charged a little for repairing. Thank you.
Posted on Aug 14, 2007
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Edge Of Scan Overexposed
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Oct 05, 2008 | Nikon CoolScan V ED Film Scanner
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
Can I scan slides with Canoscan LiDE600F
Yep, The Canoscan LiDE600F is capable of scanning slides, however it is not possible to scan them in their mounts. If you dismount the slide, you can scan them using the film strip holder. This is not an elegant solution and you would have to remount your slides to use them as originally intended.
May 05, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Dark streak when scanning film on canoscan 8400F
please clean scanner mirror then solve this problem
Sep 06, 2009 | Canon CanoScan 8400F Flatbed Scanner
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Narrow straight line runs across all scanned images
by shutterup
I solved my problem.
It's pretty personal, but I hope it can help others.
First: I might have created the problem myself because I slightly adapted the slide-mount.
Why?: Some time ago I had some unwilling films the automatic! film-mount wouldn't swallow, so I had to use the manually operated slide mount.
I adapted a slide housing a bit, so it could take and transport film.
To be short: In the end, there was transparent, (but also reflective) material inside the Coolscan V housing, close to the slide.
I removed it.
Second, I turned the scanner 45 degrees, and gave it a calculated whack on the side. (like you did with your tele in the 6ties, but a bit more carefull )
Don't know which one did the trick, or both. I can send a sample.
Mar 29, 2008 | Nikon CoolScan V ED Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
447 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
