Jvc tv fuse always burned how to trace shortge
    Master:
  • 879 Answers
To trace the short in the power supply regulator baord, you should have through knowledge in electronics and about the working principles of components used there. Moreover, you must have a multimeter, knowledge to use it and so on. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 02, 2012
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
Why all power windows stop working at same time honda accord 2002
The most likely reason is a blown or loose fuse. Hondas also use a special controller on the driver's window control panel, and these controllers are notorious for burning out. As always, after confirming that the fuse is good, the best way to start is to get out your volt meter or test light and make sure you have voltage at the window control panel. From there, you trace back to find a broken wire between the door and the fuse panel or trace forward through the switch.
Apr 05, 2012 | 2002 Honda Accord
JVC I'ART PRO WILL NOT TURN ON
hi keith, if it smokes a bit leave unplugged and get a engineer to have a look at it straight away good luck
regards
shaun
Nov 27, 2011 | JVC AV-56WP30 56" Rear Projection...
Does not power up at all no lights,
Try to check the fuse if not busted, the fuse is located at the main ac supply of your tv try t0 follow the ac cord and it will direct you to the power supply of your tv, it has two lines try to check or trace both lines to locate the fuse, if the fuse is only busted no burn marks try to replace with the same rating but if the fuse glass is covered with black that looks like something is burned inside dont replace it the other parts of your tv has a damage specially the regulator and the rectifier is shorted. Note before removing the back cover of your tv you should be sure that you unplug it first cause one mistake could cause serious injury. Good day and be careful.
Jul 14, 2011 | Sanyo Televison & Video
Bowing fuses
you need to repair the power supply section of your tv.there is a shorted parts in there that's why it keeps on burning your fuse.
Jul 17, 2010 | JVC AV-36D503 36" TV
TV will not turn on since electrical storm
yes, a fuse need to check. open back cover and trace for possible burn fuse or ckt. if burn ckt found your unit need to bring nearest service center for possible replacement.
Jun 02, 2010 | Televison & Video
My tv died last night no power at all no stand by light or sound It is a Samsung Tantus Model number TXN3298HF CRT
check first power ac cord by removing back cover trace if ac line voltage found, check for possible burn fuse. make a record after that scenario trace and log voltage trace from power supply ckt area.
Mar 26, 2010 | Samsung TXN3298HF 32" TV
WHEN PUT ON THE TV,THE INTERNAL FUSE BURNED
check input circuit. trace bridge rectifier circuit.. make sure its good.. check tranformer or line filter.
Fuse is probably burning as a precaution because there is a problem in the input section.. either ac side or after bridge
Dec 16, 2009 | Daewoo DTQ-20V1FS 20" TV
I have a JVC tv only 1 year old and the picture is getting dark.
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
