Question about Health & Beauty
What meaning E3 in Fisher & Paykel "Sleep Style 600" CPAP ?
  • jalilzadeh Dec 05, 2012
    sorry E32 meaning error 32
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
My Fisher and Paykel icon Series auto CPAP does not start
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 05, 2016 | Fisher and Paykel Washing Machines
What does a CPAP breathing machine actually look like?
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-0.jpgTHIS IS ONE KIND BUT THERE ARE DIFFERENT TYPES OF CPAP MASK
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-1.jpgTHIS ONE COVER THE NOSE AND THE MOUTH.
THE OTHER TWO THAT I KNOW OF COVER EITHER THE NOSE OR THE MOUTH ONLY.
Feb 13, 2013 | Health & Beauty
What is CPAP? I know it's something to do with sleeping and snoring.
CPAP stands for Continuous Positive Airway Pressure. It involves wearing a pressurized mask over your face while you sleep at night to help force air through the airways.
CPAP is used to treat sleep apnea and heavy snoring but the machine is very noisy and it's not comfortable to sleep with, so it's worth trying other solutions before turning to CPAP for help.
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykel Washing machine Intuitive Eco Error 130 then Error 136
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
May 31, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Where can you find a fisher paykel GW11 pump for $25 as quoted in your response? Thanks!
go online to fisher & paykel factory parts search and you have to look but they are in there I dont remember $25.00 but its close
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Where can you order parts for Fisher Paykel GC36WAC Cooktop?
These people can get anything you need for Fisher-Paykel:
http://www.fisherpaykelparts.net
If you don't see it, ask them. They can get it.
Jan 28, 2009 | Fisher and Paykel GC36 Gas Cooktop
Health & Beauty Logo
69 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
