Question about Vacuums
HOW DO I REPLACE THE TOOTHED BRUSH ROLLER BELT ON MY PRO 8910
PLEASE CAN YOU SHOW ME INSTRUCTIONS HOW TO REPLACE THE TOOTHED BELT FOR MY BRUSH ROLLER THANK YOU.
  • Vacuums Master
  • 18,394 Answers
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
SOURCE: Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: roller brush doesn't turn
Sometimes you have to replace the brush roll itself depending on what kind of vacuum you have.
Posted on Aug 03, 2009
  • 1619 Answers
SOURCE: Caught shoe string in roller brush, now will not rotate roller BR
Belt maybe streched and hardened from heat replace and try again.
Posted on Apr 15, 2010
heatman101
  • 43501 Answers
SOURCE: How do I change the belt on my Bissell Pro Heat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twerw
Posted on Sep 30, 2010
Belts aren't broke roller still won't roll
Belt dosent have to be broke it may be stretched. It needs around 30lbs of pressure to roll the brush on carpet.
If it dose not roll off carpet at all the brush bearing are locked up. You may be able to remove the roller and check theme. Most likely you wil need a new roller brush.
Aug 08, 2014 | Bissell 8910 ProHeat Clear View Upright...
Replace belt on Bissell 7901 Proheat
On the underside of the unit, you will see a red cover about 1 inch square held on by a phillips screw on one end of the brush roller unit...remove it & you will see the toothed rubber agitator brush belt.
Sep 05, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How do i replace the brush belt to my bissel pro heat carpet cleaner?
Follow the link below for belt change instructions on bissell.com.<br /> <a href="http://www.bissell.com/VideoRating.aspx?id=1555">http://www.bissell.com/VideoRating.aspx?id=1555</a>
Aug 25, 2010 | Bissell 8910 ProHeat Clear View Upright...
Brush assembly won't spin
you must replace the pump thats what the belt is attached to
Dec 01, 2009 | Bissell 8910 ProHeat Clear View Upright...
I would like to see how to change the belts on the bissell 8910 pro heat I have looked for hours now. I saw the book but it mentions and shows nothing on how to replace them. Help please.
turn the vacuum over so that the bottom side is facing you, remove the 4 screws on each side using a Philips screw drive set the screws and the brush cover aside.
- pull brush straight out and you will see the gray rubber band.
-replace the new drive belt over the motor pulley and the floor brush.
-replace the floor brush by lining up with the slots and rotate untill centered , install the cover and screws . done your back in action.
Hope this helps.
Sep 05, 2009 | Bissell 8910 ProHeat Clear View Upright...
Need directions for changine belt for brushes
There is a door on the side pop it off remove the old belt and simply slide the new belt on. Over the motor shaft first then the roller brush end.
Apr 12, 2009 | Vacuums
Cant put the roller back on right!
The user manual has a diagram and instructions and is available online.
I could try to walk you through but their diagrams and instructions are pretty good.
A couple tips....the small red plate screws in laying flat and the largers one slides in sideways.If you try to match the screws holes up it may help.
Also the first time I had troubles we called Bissel and someone helped us.
Nov 30, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissel pro heat /brushes do not turn
Belt worn or hair build up can clog it from spinning. I've seen this on other models. Just remove the hair slowly. If the Belt is worn you can replace that from Bissel or any store that sells their product.
Check to ensure that the pump belt and brush belt are intact and installed according to the instructions provided in the User's Guide.
The pump belt is located under the belt access door on the side of the machine. This belt should be looped around the red pulley and the silver motor shaft.
To check the brush belt, please follow these directions:
Turn the machine OFF and unplug from the wall outlet.
Step on the handle release pedal to lay the handle down on the floor.
Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
Turn the machine over to expose the brush.
Look for the red retainer plates, which hold the black brush arms in place. Remove the two Phillips head screws to access the toothed brush belt. Check to ensure the belt is intact and looped around the brush end, as well as the red pulley with the ridges.
Remove any dirt or debris from the brush assembly.
Inspect brush, brush arms, red brush arm retainers and red pulley for damage and replace parts if applicable.
Jul 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
