Hotpoint wt940 is flashing F12
WONT TURN ON AS IT IS FLASHING F 12
SOURCE: Flashing F12 on display
F12 is either the motor, or eprom chip on pcb. Most likely to be motor
Posted on Jul 11, 2007
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washing Machine WT741
Error code F12 is indicating a communications error between cards, this can be caused by one of several things..
A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is a electrical problem as opposed to a mechanical one.
If you cannot eliminate the problem your self, then i'm afraid your only other option would be to call an engineer out, it can be a difficult problem to pinpoint correctly.
Please leave a rating for my suggested solution.
Thankyou.
Posted on Jan 30, 2009
  • 8 Answers
SOURCE: machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
Posted on May 28, 2009
  • 8 Answers
SOURCE: Hotpoint WT940
Blockage in pump
Posted on Jan 11, 2011
Hotpoint washing machine WT960 is flashing F-12
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODESAccording to hotpoint website
Nov 26, 2011 | Hotpoint Washing Machines
My washer is flashing F-12 what does this mean?
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PCB, just needing re-seating- by an engineer ;-0(
John C
Mar 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine wont work and flashes f12 on function display
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
f12 is a communication error between the circuit boards. engineer job. if the machine is less than 5 years old the parts are free but the callout +repair's about £100 from hotpoint.
Jan 25, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint fault f-07
F07 means that the heater relay is stuck, you need to test the heater and replace if req'd.
If heater o/k then you still have a problem with the heater circuit somewhere.
Maybe a control assy
Plz rate this solution.
Thanks, and a merry xmas.
Dec 20, 2008 | Washing Machines
WF860. Machine auto fills when power come on
this is for standard hotpoint washers.
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
this is for hotpoint lcd evo1 washers.
F12 - Communication error - Book a service engineer.
this is for hotpoint lcd evo2 and v4 washers
F12 - No communication between cards - Book a service engineer.
please do not for get to rate and comment about your experience with fixya today.
Aug 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
6,982 people viewed this question
Top Washing Machines Experts
