Question about Maytag Neptune MAH6500A Front Load Washer
Washer won't agitate
My maytag neptune washer fills with water, but won't agitate, it just makes a hummmming sound like it wants to turn but doesn't. Is there anything I can do to fix problem or do I need a repair man?
    New Friend:
  • 88 Answers
Open the back check the belt also see if u can turn it by hand. if that doesn't help call repair man .
Posted on Jan 11, 2009
My Neptune washer doesn't empty all of the water. Is it suppose to hold water?
The Maytag Neptune front load has a liquid counter weight that makes it sound as though it is not empty. This is a normal sound, they all sound like that, even mine.
Jan 26, 2013 | Maytag Neptune Washing Machines
Maytag Neptune TL washer doesn't stop adding water
it sounds like your drain hose is to low it needs to be 3 feet high if its to low this will cause the water to syphon out and keep refilling
Nov 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Maytag top loader won't agitate. will fill and spin
Try this:
When the washer should be agitating, try turning your load size switch back and forth a few times. If you are on a medium load, going to a larger load should cause it to begin filling again, going to a smaller size should start the motor for agitate. If this works, your pressure / water level sense switch is okay, but the switch for load size is faulted / or is on its way out. If you went from a medium load, to a higher load, then your pressure switch is faulted as well.
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
