Question about AOC L42H861 42 in. LCD TV
How do I correct overscan on an AOC AOC L42H861 42 in. LCD TV?
How do I correct the overscan on my AOC L42H861 42 in. LCD TV? It is really bugging me. I've heard I can use the service menu, but I can't find the code for it.
  • CyberSkull Dec 02, 2012
    I found the factory menu code. Set volume to "0", press "mute", press 9-8-7-6. There is no overscan on the factory menu.
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
How do I perform hard reset for AOC monitor. Menu reset doesn't fix problem.
There are only two types of resets. Factory reset, and Hard reset. To make a hard reset, you have to unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. Within this time it might have been resetted. To do a Factory reset, you have to enter its service mode option. Electro help . Try this link to know more. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | AOC L24H898 24 in. LCD TV
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
Nov 26, 2011 | AOC L22W898 22 in. LCD TV
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
When darwing in AutoCad, circles appear as eggs!
It is because your monitor is not getting the correct navtive resolution from your PC, the aspect ratio is not correct, the PC video output should be set to 1680x1050 @60Hz for this monitor. This monitor 16:10, not 16:9 like other 16:9 monitor.
Mar 21, 2010 | AOC 2219S1 22 in. LCD TV
I can not get "fullscreen" on tv via laptop--when i click the "fullscreen " icon in laptop toolbar it freezes tv rather than going full screen
You should search for how to get "overscan" on your laptop model. ... I have a mac mini plugged into an LCD tv and in order to get it fullscreen i had to enable overscan.
Oct 27, 2008 | LG 42LC7D-UB Television
AOC 15' LCD TV
go to local radio shack
http://www.radioshack.com/product/index.jsp?productId=2103894&cp=&sr=1&origkw=computer+power+cord&kw=computer+power+cord&parentPage=search
Dec 10, 2007 | AOC A15X221 15 in. LCD Television
AOC L42H861 42 in. LCD TV Logo
281 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
