Question about LG LRFD21855 Stainless Steel French Door Refrigerator
Error code IF or 1F not making ice model #795,77562... Sears/LG
Bottom freezer, french door. Ice maker in top of the left hand door. Unplugged for three hours, no help. The ice maker was turned off for two weeks while on vacation.
  • 1 more comment
  • eiw1935 Jan 17, 2009
    Sold as Sears Kenmore, made by LG, maybe mix up in #. Had one estiment done, $395.00 must replace moter and ice maker. This model has below doors freezer and the ice maker is located in the upper left hand door.
    Thanks MNTECH for your help! Wher is circuit board located? My rating for you is a nine!!
  • Rch1019 May 03, 2009
    HI. Code ER 1F appeard on the display of my Kenmore 795.7756. From reading these posts is this an ice production issue?
    Thanks,
    Rodney
  • Anonymous Mar 13, 2014
    er 1f code indicates ice maker fan not working. where is fan located
  • 1,543 Answers
You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
Posted on Jan 11, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jan 17, 2009
    Still no model number, so unable to give part numbers, etc., but there is a communication board in most of these type refrig's just behind the dispenser recess in the door, in addition to the main board on the back (or sometimes on the top) of the refrigerator. (but I suspect the main board is OK) Hope you can get your unit into the Fix-Ya condition.
What does Er 1F mean of the control panel?
I believe the 1F error indicates a problem with the ice maker. This could be an issue with the ice maker fan icing up, the fan motor failing or the PCB board that controls the fan. First try unplugging the power to the refrigerator for 8 hours. This may reset the error code. Next check if the fan is spinning freely. If the fan has iced up, then the motor could fail from the attempt to spin the fan.
If you add a comment with the full model number, I may be able to give you the parts information. (Look inside the refrigerator for the model number; there is usually a plaque with that data on the side of the fridge.) If your refrigerator is under warranty, contact Kenmore.
I hope this helps.
(If you turn off the ice maker after resetting the code, you probably won't see the error again.)
May 14, 2015 | Kenmore 72093 Elite Stainless Steel 32.5...
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I...
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Mar 21, 2011 | LG LFX23961ST Stainless Steel Bottom...
Error code is 1F - the fan has stopped working
My 2 year old LG LFX23961ST refrigerator started showing error code Er IF. In searching help here,
I found out it meant the problem was with the Ice maker Fan. When I checked the ports where the cold air blows into the Ice maker compartment, there was no cold air coming out (you have to hold the door switch in to turn on the fan). I removed the ice maker module (two screws) and unplugged it. When I closed the door, the fan started running, but was making a rattling noise. I suspected ice build up.
Emptying out the freezer compartment, I pulled the rear cover of the compartment off and found what I had suspected. Cleaned out the ice, put everything back together and Voila! Everything working again.
As I write this, I can hear ice dropping into the ice holding tray. Not sure yet why the whole ice blockage thing happened though. Will keep an eye on it. It's been several hours since the repair and no issues. All seems well. It's not rocket science. If you can use a screwdriver, you can fix it too.
Dec 20, 2010 | LG LFX23961ST Stainless Steel Bottom...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Ice maker don't make ice and display code error
The ice fan is frozen. It is located behind the rear panel inside the freezer drawer. I had the same problem in November 2008 that was fixed under warranty. They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Sep 07, 2009 | LG LFX25960ST Stainless Steel French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
337 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
