Question about Hotpoint WMA54 Front Load Washer
My hotpoint WMA54 wont spin
The drum is going round but not speeding up to spin. PLEASE HELP. Thanks
    Sergeant:
  • 198 Answers
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Posted on Dec 02, 2012
amgm
  • 32 Answers
SOURCE: Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Posted on Feb 12, 2009
mosescape
  • 3 Answers
SOURCE: Hotpoint WMA35 - water will not empty and will not spin
Hi Debbie
Posted on Feb 20, 2008
IFIXALL
  • 868 Answers
SOURCE: hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
Posted on May 24, 2008
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
Drum not going round at all
can i Have the complate Model Number so i can get you back up and running?
Feb 09, 2014 | Hotpoint WMA54 Front Load Washer
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Dec 12, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Thanks.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
Clothes still too wet after complete cycle
I would suggest that the filter wants cleaning.
To access it, remover lower rear panel of washer.
Locate and remove the large black hose on to the tub.
Be careful, as there will be water in the hose.
Remove and clean plastic filter inside hose.
Refit hose and filter..
I would also suggest that you remove motor and check the brushes for wear, whilst you have the rear panel off.
If there is less than 10mm showing, then they need replacing..
Please leave a rating for my fixya solution.
Thanks.
Feb 07, 2009 | Hotpoint WMA54 Front Load Washer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
