Question about Water Heaters
Central heating boiler will not heat heating water
  • 4 Answers
First do not call engineer go up in loft if there is a lot of insulation in loft have some boards to lay down in loft you will have two water tanks one large and a much smaller one look inside the smaller one and if the ball valve is stuck in the upright position and no water in tank move ball up and down water should flow wait for tank to fill then bleed radiators with a small key obtainable at most diy stores for this you will need a small towel with key hold towel under valve loosen the screw at top of radiator air will escape then water will escape do this to all radiators repeat this a second time so only water comes out turn on heating system also there is a chance you will have to turn down heating system
Posted on Jan 26, 2013
SOURCE: gas central heating boiler. insuffient water pressure.
u need to have a key (its like a T shape key) and u put that under the boiler its a hole in there, than u open the tap which is near this hole.
Posted on Oct 31, 2008
robocop
  • 90 Answers
SOURCE: I need to restart my boiler after running out of oil
Try a website called www.repairclinic.com and see if that will answer your problem.
Posted on Jan 20, 2009
  • 30 Answers
SOURCE: valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Posted on Mar 30, 2009
SOURCE: Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Posted on May 01, 2009
  • 150 Answers
SOURCE: alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Posted on Sep 02, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Water Heaters Logo
75 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
