Question about Canon ImageRunner 4570 | IR4570 |
I have e000100-001 and e 000110-0001 in ir4570
It was working with 60gm paper and when it gave me this error i changed paper kind and worked with 70 gm paper now it doesnt work with all 70 gm it works with the the dark paper of 70gm not the bright one what is the solution when i work with it it works for 3 or 4 papers and it give me that error
SOURCE: Paper does not feed and E3 error code is flashing
I have one of these printers and have found the problem, crappy enigineering and inferior parts. Looking at the printer from behind, on the left side (where the motor is located) There are two white gears, located at the bottom and behind a larger black gear. One is of medium size and has a spring. The other is smaller and slides into the medium gear. If you can get these two gears back together and in their proper location, then you're set. But, if you're like me and get frustrated easily, DON'T TRY IT! I broke mine :( A repair will cost as much as a cheap printer, so bite the bullet and hit-up your local rite-aid, they have printers that wont bust the bank. Keep your MP 150, after all the scanner/copier will still work without its attached printer.
Posted on Nov 06, 2007
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
shaqseti
SOURCE: canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Posted on Oct 21, 2008
  • 1126 Answers
SOURCE: paper jams at heater section in ir4570
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
Posted on Jun 15, 2009
roit
  • 28 Answers
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Posted on Sep 04, 2009
Paper jam?
my dear you change paper feed roler
Aug 06, 2015 | Canon ImageRunner 4570 | IR4570 |
IR4570 Paper Jam on Duplex
" Re: iR4570 Paper Jam on Duplex Mode
IR 2270, 0108 & 0207 jams your code is the fuser sensor but I would think about adjusting the loop esp if the paper is coming from an optional lower cassette.
FIRST THING I would do is replace the pads for the flapper figure 140 item 6 in parts manual. the two black foam pads were changed to a stronger white pad. These can cause your problem.
The updated pad number is fc9-4659 you need at least two . Plus you need to make sure the metal cover is on your registration sensor. fc7- 9370 ." http://www.copytechnet.com/forums/canon/68195-ir4570-paper-jam-duplex-mode.html
Oct 11, 2014 | Office Equipment & Supplies
Ir4570 email
Sorry, wxygzgc, but there is no indication at all in the Users' Manual that the IR4570 has any email capability.
http://www.agercopy.ro/poze/24547_1_Manual%20Utilizare%20IR%202270_2870_3570_4570.pdf
May 20, 2014 | Office Equipment & Supplies
What weight of paper will the CLP300 take? For example 160gm is this possible.
The specifications for the CLP-300 say it should take paper of 60gm to 163gm but in practice I have found that 160gm is too heavy and will not feed through as is too stiff.
Sep 11, 2011 | Samsung CLP 300 Laser Printer
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
Cannot remove paper jam message
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 28, 2010 | Dell 926 All-In-One InkJet Printer
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
May 21, 2009 | Canon Office Equipment & Supplies
hi,
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon ImageRunner 4570 | IR4570 | Logo
129 people viewed this question
old marine
old marine
