Question about Garden
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I took a 25 hp Kohler Engine off of a (GT5000 Garden Tractor 917.276013) & I am trying to wire a 18hp B&S engine to the chassis. I know which wire is for power but what do I do with all the other wires? The Kohler Engine is discarded at this time.
  • 8,404 Answers
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in FixYa.com
Posted on Dec 02, 2012
  • 1 more comment
  • Gary Adkins Dec 04, 2012
    Thanks for your help! I downloaded the wiring schematic on the GT 3000 & the 18hp. I'll follow the wires tomorrow.
  • A Miller Dec 04, 2012
    Good solution ... good luck with your project. Kohler is a good engine, sorry you lost it though B&S, too, is a good engine.
  • Gary Adkins Jan 22, 2014
    I removed all of the old wires & started from scratch with a basic wiring diagram. It works fine! Thanks A. Miller!!!!
3 Suggested Answers
ImpalerCo
  • 13 Answers
SOURCE: replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
panilling9
  • 284 Answers
SOURCE: I blew the 24 HP ELS 725 Briggs & Stratton
http://www.smallenginewarehouse.com/
this site may help
Posted on May 17, 2010
Testimonial: "Thank you for your help!"
How much oil does the engine take for an oil change
Briggs & Stratton engines typically take 48 ounces of SAE 30 oil.
Kohler engines typically take 64 ounces (2 quarts) of 10w30 oil.
Always refer to the dipstick to ensure proper amount is added and do not over fill.
Apr 24, 2016 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Briggs & Stratton 19.5 HP engine
just had the same problem found the internal jets in the carb plugged took it apart and soaked it for a couple days runs great now
Apr 22, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Type of oil to use for my Craftsman 24 hp riding lawn tractor
Hello, if you have a Kohler engine you would use any 10w30 oil, but if it is a Briggs & Stratton you would use SAE HD30 oil. Either can be purchased from your local auto parts store. When you refill be careful to not over fill. Use the dip stick to ensure you have the proper oil level. Over filling will cause the engine to smoke under load or possibly blow out a seal. Good Luck!
If this was helpful, please vote yes. Thank You!!
Apr 09, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a Craftsman , with 25 HP Kohler engine & 50in. deck. Just stoped running whlie mowiing. Now won't start, Sounds like battery dead. Checked seat safty switch by jumping eires, did'nt solve problem
My Briggs and Stratton did the same. Look under the hood along the wiring harness for a 20 amp automotive type plug in fuse. Mine was blown, but fuses blow for a reason. One of my headlight connections came loose and shorted to ground. If yours has that fuse look for a short.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Will any other engine fit a craftsmen 26 hp lawn tractor other than the kohler
Yes there are 2 other options.
Briggs and Stratton, and Onan.
Here is the information. You will need to have your output shaft size.
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replacing engine. Briggs 26hp on GT5000 garden tractor
Mar 07, 2009 | Briggs & Stratton Garden
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
