Better graphic card
I have compaq presario a900 and want to play just cause 2 on it in maxed out 60 fps i dont hafve good enough graphic card so can replace with nvidia geforce gts 250?
  • 4 Answers
How to solve this problem
Posted on Dec 02, 2012
tom19511
  • 1601 Answers
SOURCE: graphics card
In order for Cold Fear to run properly, your PC must meet or exceed these minimum requirements:
Opertaing System: Windows 2000 / XP Only
Processor: 1 GHz processor minimum, (2 GHz recommended)
RAM: 256MB RAM minimum, (512MB recommended)
Video Card: DirectX 9 compliant 64MB (128MB recommended) see supported list *
Sound Card: DirectX 9 compliant
DirectX Version: DirectX 9 included on disk
DVD-ROM: 8X or better
Hard Drive Space: 2.2 GB
Peripherals: Mouse, keyboard, Windows compliant game pad.
* Supported Video Cards at Time of Release
Nvidia GeForce 3/4/FX/6 series (GeForce 4 MX not supported)
ATI Radeon 8500/9000/X series
These chipsets are the only ones that will run this game. Laptop versions of these chips may work but are not supported
NOTICE: This game contains technology intended to prevent copying that may conflict with some DVD-RW and virtual drives.
Also, make sure that no other programs are running.
Posted on Dec 11, 2007
the_fire
  • 432 Answers
SOURCE: GeForce 8600 GT 256MB DDR3 PCI Express Graphics Card doesn't work
contact the shop / place you purchased it from and they should be able to give you info of where to send it and what to do - they should have a section on there website where you can go through the return process and you will most likely need to get an RMA number to authorise the return / replacement.
Posted on Apr 11, 2009
  • 39 Answers
SOURCE: Graphics Comparison
I beleive that your onboard is pretty much the equivelent to the geforce card you have spec-wise. But the 3300 a much new technology and has a faster processing speed in comparison to the geforce 6600 (not sure about the 7200).
In anycase, if you get yourself another ATI HD card (2400, 3450, or 3470) you can actually run them both as a Crossfire set up. Also, you can slight overclock your onboard video just a tad if that is a route you wanted to take.
The HD 3300 onboard was meant to be a better option over more entry level cards on the market today.
If you're still not sure, you can always do a 3dmark or gaming FPS test on each gpu to see which gives you the best outcomes.
Posted on Apr 18, 2009
Sphynkter
  • 221 Answers
SOURCE: nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
Posted on May 13, 2009
  • 490 Answers
SOURCE: NVIDIA GEFORCE GTS 250 COMPATIBLE ?.
this card should work on that system altho i need more info bout your pc to be sure, another thing i rang up the other week to purchase a high end card a geforce GTX 295 and they said that i would also have to upgrade my power surply unit to double what it was so this could be your problem easy way to do it ring any computer store and they shud be able to tell you what you need and also the compatibility specs should be on the box it came with
Posted on Aug 24, 2009
Testimonial: "OK I WILL CHECK MY POWER SUPPLY UNIT TO MAKE SURE THIS CARD WILL REALLY WORK WITH MY PC"
My fps will not go over 70
Ur fps depends upon the game ur playing. If ur playing high end game with a low graphics card ur fps will be low. Switch to a higher graphics card for good fps
Apr 14, 2014 | Evga : GeForce FX5900XT DDR128MB TV&DVI...
I have a compaq presario cq61-410US and I use it a lot to play a game called League of Legends. It often has fps drops and freeze ups though. Im not sure if it's because of the computer proccessor
You have a Graphics Adapter integrated into the Motherboard it's not upgradable Disabling unnecessary processes will help quite a bit. Adding more RAM is a option, depending on your OS, 32 or 64bit? 32bit will use 3.80GB's or so, 64bit 4GB's or more. your specs say you have Windows 7 64bit with 2GB's of memory, is that correct? If so add up to 4GB's of Memory Max, SEE: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c01966130 In the BIOS you MAY be able to adjust/increase more Shared Video memory? The game usually has a Optimal Setting for your machine. Have you done ALL your Updates for Windows and HP? ALSO I use RAZER GAME BOOSTER freeware on my lower spec machines to disable ALL unnecessary processes, you configure what you want to disable during game play: http://www.iobit.com/gamebooster.html Give it a try , it's safe, free and works for me.
Mar 28, 2013 | Compaq Computers & Internet
Fps drops from 2 to 5 seconds while gaming
if you have installled the game the virus may be cd.just opt for an antivirus.
Feb 08, 2013 | Acer Aspire 5742G
Freezing
Probably not a power issue if games play ok.
Could be your computer processor is too slow, not enough ram, driver settings, video codecs, graphics drivers or combination of any of them.
Apr 15, 2012 | Apple ATI RADEON HD 5570, (1 GB) PCI...
COMPAQ LAPTOP ALWAYS EXPERIENCE HANG WHEN PLAY GAMES
your graphic card is not large enough.also if you turn down the graphics the game will play better/
Jan 04, 2010 | HP Compaq Presario F761US Notebook
Low frames per second while gaming
The FPS in your games is primarily controlled by your graphics card. The better the card the better the fps. To get the best possible fps in gaming you should be using a good quality card like the NVidia GTX 260 card or better or an ATI Radeon 4870 or better. If you have the money you might want to upgrade. If not try turning off all but your essential background processes & see if that helps. Good luck.
May 09, 2009 | Computers & Internet
Pixel shader 1.1
Hi.
Your problem is with your graphic card.
Seeing that it shows an error of pixel shader 1.1 i can only guess that either you are using video card provided by compaq.
Only solution get a good graphic card.
I suggest one from nvidia.
Oct 12, 2008 | Computers & Internet
Lag on my Computer?
i think getting 2gb of ram will make your computer go much faster and wont lag but if u do that ur computer might be to fast for ur graphics so it will look choppy so u might need both.
Jul 13, 2008 | Compaq Presario Notebook
Sound driver of compaq presario a900
Link
Run
install reboot the run and install this
This will create a swsetup folder in c drive link ("C:swsetupsp34200")
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click
Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:swsetupsp34200 folder and select the .inf (wis30b2a)
file and click open and Continue with the onscreen instructions.
Regards
Fixya member abgog
Jun 30, 2008 | Compaq Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
