Question about Kenmore Microwave Ovens
Microwave stopped heating
This morning I was about to warm my coffee. When I hit "start" there was a little flash and the clock display went blank. Then I reset the clock (it took) and put the coffee in. The internal light came on and the turntable was spinning but there was no heat. Is this an easy problem to repair? It is a Kenmore Model 721.63252300 and is only 3 years old.
  • Kenmore Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a blown high voltage rectifier diode.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number at the Sears parts site.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Jan 12, 2009
I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
Aug 11, 2011 | Microwave Ovens
I warmed up a cup of coffee in our microwave then
This usually means that the magnetron circuit has failed. The magnetron is the part that generates the microwaves to heat the food. Typically the problem is the magnetron itself that has died. The cost of replacement comes close if not more than a new microwave oven. Unless the oven is still under warranty, it not worth fixing.
Feb 14, 2010 | Sharp Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
