Question about Cell Phones
I got a problem with my Xperia play it's screen got struck nd became full of colourful dots buttons have not worked I even factory reset it but no use.What to do..??
    Master:
  • 368 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 02, 2012
  • Sainath Reddy Dec 02, 2012
    My IMEI 357302041651497
HOW TO RESET WITHOUT TOUCH SCREEN
Using Hardware Keys Step 1Press and hold the "Power" key to turn off the Xperia Play.
Step 2Remove the back cover, and then take the battery out of the phone. Leave the battery out of the phone for a few minutes, and then replace it and the cover.
Step 3Press and hold the "Left" and "Right" directional keys under the screen.
Step 4Press the "Power" key while holding the "Left" and "Right" directional keys. The Factory Data Reset menu displays.
Step 5Use the directional keys to highlight the "Factory Data Reset" option, and then press the "Power" key to select the option.
Step 6Follow the instructions to complete the data wipe. The device powers down, and then boots back up. When the Xperia Play turns back on, factory default settings and software are restored.
Sep 24, 2014 | Sony Xperia Play R800x
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
I have a monitor that keeps flashing colours and can't turn off. Many threads tell me to reset it to factory settings, but how do you do that if you can't even get the menu to come up?
Try holding the menu button in for 10-15 seconds. Try pushing both power and menu buttons together.
It may be toast.
Take care!
damnor01
Sep 12, 2012 | Dell E197FP
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Need to reset sony ericsson xperia 10x cell phone
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
Aug 08, 2011 | Sony Ericsson Cell Phones
1ST IS : 1-Turn off your Sony Ericsson Xperia
2-Remove the battry and replace it back in
3-Press anda hold down the left and right silver buttons just under the screen
4-With the stylus,press in the hole on the right side of tehe battery
5-After 10 seconds,you will be prompted to press the R key on your silide-ou keyboard
6-If successful press the Space Key on your slide-out keyboard to finalise changes 2nd IS :
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
This is a soft rest its never hardrest, pls we someone to give haedrest solution,-even when there is password, which can be removed easiy
Aug 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I can't start my phone and need to doo a complete reset. How can i do it? Thanks Regards
How to hard reset the Sony Ericsson Xperia X8First, try this:
  2. Tap Settings, then Privacy
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
Jun 18, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  4. Tap Reset phone
The password is user defined, try the second method if you did not set a password.
Good Luck!
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
Mar 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I can't remember my gmail account information and I am locked out of my xperia phone from too many pattern attempts. No combination I try will work.
Try to enter password as null. If didnt worked means do a hard reset . You will get factory settings enabled after resetting.
Mar 06, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
