I have a system that has a turn table cd radio and twin Tape deck but I was not shown where all the connection wiring goes are you able to assist please Cassette deck is FC 261 Tuner FT 261 await any
Sorry I wasnt more clearer I am looking for the connecting wiring diagram for the system
  • Ian R Taverner Dec 09, 2012
    The problem is it a 240,v system with turntable, twin tape decks.Tuner ,CD and what is possibly the amplifier the leads are red and white connections are the same both ends I am unsure which go into where is it woth wilr sending a photo of the back of the units await you reply thanksIan
  • Audio Player... Master
  • 1,258 Answers
If you have all the cables it is no secret how they go in. They are either different in length or they will have different connectors on them so you do not make a mistake. Connectors and wires in these things are not too different- If a 5 pin ribbon cable can plug in both connectors and the length of the cable seem right then that is it. I have worked on many of those system and they are not made to last nor be repaired. When you do work on them they usually have multiple problems. That is why it is better to have separate components.
Posted on Dec 06, 2012
5 Suggested Answers
fairlane
  • 50 Answers
SOURCE: No sound on cassette deck
Hi Does the deck have VU meters?...or a graphic display of some kind to indicate there is sound being picked up from the heads? If there are, and they are not moving or flashing, as the case may be, then you could have a wire off the head, or a problem in the preamp circuit, or if the deck is older, it could be as simple as a dirty play/record switch. I would need more info to help further. Good Luck!
Posted on May 02, 2007
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
petraman7
  • 1175 Answers
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Posted on Mar 25, 2010
I don't know how to get the turn table to start
Once the turntable mode is selected picking up the arm and moving it to the record should start the deck spinning.
Oct 13, 2014 | Audio Players & Recorders
Tape recorders.
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 25, 2008 | Audio Players & Recorders
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
Sep 09, 2014 | Sony RCD-W500C 5-Disc CD Recorder
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Hi! I got Sansui DA-T550 reciever which is a bundle with amplifier, FM, tape deck and separately connected automatic grammaphone. THe problem is with tape deck. When the whole unit is turned ON, the...
Hi Taff,
I had this problem too. In the end I opened up the box ( a real nightmare) found a "computer ribbon" style wire between the tape bits and the amp bits and disconnected it. I can't use the tape anymore, but it doesn't make any noise either. Like you (in your solution) I hate the way it switches to the radio when a record finishes. I have a CD player connected to the aux play jacks - when the aux button is pushed in, the radio is disconnected and when the CD finishes, you get silence not radio.
Dec 08, 2010 | Audio Players & Recorders
I have been given an old JVC stereo for my son - its all separates though we wont be using the tape deck - anyway I just dont have a clue about what wire goes where and its driving me nuts!!!!!!! Is there...
You don't mention the model number, so this info is generic:
Think of it like water flowing, in one end and out the other. Each patch cord will run from the input to an output. The receiver or amplifier has inputs for the tuner, tape deck(s), turntable (sometimes high & low) and auxiliary, which could be TV or whatever other sound source you have, a cd player, e.g.
The outputs from the various sound players will go to the inputs on the receiver. The tape deck will also have an input - that's for the tape out from the receiver, which sends a signal of other sources to the tape for recording.
If there's a separate amp and preamp, the preamp output will be the amp input.
Use red on right, white on left, and be consistent.
Speaker wires should be connected in phase, i.e. make sure the striped side of the wire is always either plus or minus, but be consistent from speaker to speaker, and do the same on both ends of the connection, from amp(receiver) to speaker.
Here and here are a couple of links to helpful articles for more information.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | Audio Players & Recorders
I have two different music systems, need answers for if possible,
On the no disc messages, try a cd or dvd lens cleaner which ever is appropriate for the device and also try blowing canned air inside, it can be a dirty lens.
Mar 13, 2009 | Sony Audio Players & Recorders
CD can't be recognized & tape deck clicks - door can't be opened (SOLVED!)
Correction on adjusting POT to fix CD not recognizing CD. As I said I tried turning it Clock Wise (CW) just a small amount. Than tried turning it Counter Clock Wise (CCW) back to original position and past (CCW) a small about. I typo-ed that. Any way make small adjustments +/- from original direction in small steps, iterating back and forth from original position till you get success. If I had a repair manual there might be some way to calibrate it or one direction you always turn so I was hunting around.
May 11, 2008 | Audio Players & Recorders
Dvd wont play in mini hi fi system
First, you should never use commercial cleaners on CDs or cassette heads. They can create more problems than cures.
Unit may have bad disk motor or optical pick-up
May 01, 2008 | Audio Players & Recorders
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
 Grubhead
Grubhead
