Not blowinf hot Air Carrier 58sta
I appreciate your Help, I was still unable to get heat from my unit. WHen I turned off the thermostat the unit made some noise felt like it was blowing cold air. However it was only upstairs, if you have anymore suggestions please let me know, I have to get ready for work but will check this before I leave in 40 mins.
  • 700 Answers
Go ahead and shut it off and back on that should reset it for you then count the number of blinks if it goes off again. then let me know
Posted on Jan 11, 2009
I have a Carrier heating unit in my attic ,
zone controller might be stuck seek help from service co.
Mar 25, 2015 | Carrier Heating & Cooling
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like thathttp://www.scribd.com/doc/20861415/Carrier-58pav-Service-Maint i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
My carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Mar 21, 2010 | Carrier Heating & Cooling
Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Jan 21, 2009 | Heating & Cooling
Carrier Furnace is not blowing Heat
heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/58st-13si.pdf
Jan 11, 2009 | Heating & Cooling
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
