The ignition system is controlled by the ECM. Check power at fuse box in on right side under dash. Check fuses right side engine compartmentlower dash panel if all OK check power to ECM located right side "A" pillar in alloy box. this unit could be faulty if no spark at coils, assuming they have been connected correctly. may have to get tested for codes at L/R dealer or someone with test tool. Another source of problem may well be flat battery in transponder key. The indicator light on the dash willflash rapidly for 10 seconds if the vehicle has been unlocked with the remote and the drivers door is opened if the battery in remote is getting low
WITH MY EXPEREINCE FROM TIME TO TIME THE CRANK SENSOR DOES THAT TOO.
