Question about Acer Aspire 5720-4230 Notebook
Think settings for this laptop on my home network are wrong
Everytime I change a page my internet connection goes off and I have to start over again, help?
Everytime my wife's iphone connects to our home network, my laptop looses the internet connection and goes to a local connection only. I have to disconnect and reconnect and everything works fine.
I find that when it comes to iphones and home wireless networks, that using 64bit encryption is the best. I'm not sure what you are using now, but give this a try.
May 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
How do i put internet on my laptop? It'sa dell Lattitude 830 So I have a home and a laptop. The home has internet I was trying to tap into the network from home to laptop. I saw my network on the laptop...
Do you mean that you have a home network already set up? You need a router for this, make sure that the router is in DHCP enable, this will assign the IP automatically. Now, the laptop should have the very same set up. Make sure the wireless is on, go to Start, connect to, Show all connections, right click in the wireless icon, click status, click on properties, then highlight Internet connections (TCP/IP) and properties again. Make sure that "Obtain an IP automatically" is checked. Click advance, click Wins tab, checked Default, click OK. Re-start your laptop. Anything else just let me know. Good luck.
Dec 18, 2009 | Computers & Internet
I can't get my at&t mail from my laptop
check whether which connection is activated..i think the wireless connection is wrongly setup .. if u disconnect from your fathers computer ur internet will work ... so to overcome this problem.. go to internet options in your browser and go to connections--> advanced LAN settings..in that mention which network adapter is used for internet .. then the problem will be solved
Jun 19, 2009 | Yahoo Mail
Laptops not connecting to the internet when the hp c4599 is on
Perhaps the printer is conflicting with the laptop by taking its "address" on the network...Do you know how to give your printer a diifferent IP address? Or your laptop? Its a bit complicated to explain but if you can make sure the laptops and the printer are all set to use "DHCP" then they should all each get an adress on your home network and work together.
In Windows Vista, click Start, Control Panel, Network & Internet, View Network Status and Tasks. Then view the status of your Wireless Network Connection and click details, if it says "DHCP Enabled" in there then your laptops are not the problem and should be sharing addresses.
You should be able to see in the printers control panel or by printing a self test page how its setup on the network, maybe it needs to be reconfigured while the laptops are turned on as well.
May 17, 2009 | Office Equipment & Supplies
The other day i plugged a net gear adapter in thinking it would connect me to the network at work, but i realized it was just a wireless adapter, and my computer is already equipped with wireless. Anyway,...
First, I would go to the control panel (start, control panel; or start, settings, control panel). Then got to Add/Remove Programs. Scroll down the list until you find what looks like netgear software and try uninstalling there.
If that does not work or you can't find it in the list, you could try inserting the install cd again. Check to see if there is an unistall option, and perform an uninstall. Or, if not, then try installing it completely, then uninstalling it via CD.
Mar 18, 2009 | Computers & Internet
D-Link 1310
If unsure of your network key try to reconfigure your wireless network again.
Access the configuration page of your router. type on the address bar 192.168.0.1
On login type Admin leave password blank. if you set up a >password or the login page use that one.
>Once inside the Dlink Page
>Go to setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network passwork or security key and confirmed it.
>Click on Save Settings
>If it asked your to reboot then reboot if not its ok
>Using your laptop click start and go to "connect to" and click on your wireless network and connect to it and along the way it will prompt you to enter your network key or password. This would be the same as your passphrase or pre-share key type in your network key.
> Once connected to your wireless network, Open an Internet browser to connect to the Internet.
Jan 28, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Acer Aspire 5720-4230 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
