Question about HP Compaq Presario CQ40-330TU
How do I test my internal microphone, it is not working. my laptop is compaq presario CQ 40
My internal microphone is not working. I want to turn it on
    Scholar:
  • 156 Answers
Do you use any programs like skype / voip? Then in some case you have to configure the audio setting to work with your microphone. users manual can give you more knowledge. here is the link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodClassId=-1&prodTypeId=321957&prodSeriesId=3944770
Posted on Dec 02, 2012
SOURCE: Compaq Presario A900 microphone does not work
those laptops have tw microphones inthe middle, one left the other one rigth, it may be that the vloume isnt on on them or it may be that the part of the cable for the mirophones are bad beacuse of bendin the lid
Posted on Jan 02, 2009
ariyoso
  • 145 Answers
SOURCE: i have Compaq cq-60 leptop, it's microphone is not working, can u
you can see the "speaker logo" on the right side of windows (bottom right), click it twice and then appear volume control,
on volume control click "option" - "properties"
on properties you can see many feature there, checklist the "microphone" option and then OK
well u can have microphone ability
Posted on Jun 26, 2009
  • 31 Answers
SOURCE: compaq presario v3000 internal microphone not working
hi
this is gopal from hp did you see that the microphone is working or not means the hardware not the software.
Posted on Sep 15, 2009
  • 156 Answers
SOURCE: Internal microphone - compaq presario c762nr notebook not working
the steps u can try is
1. go to start->control panel->sound and audio devices->double click on it and then go to the voice tab->in the voice tab click on to volume button and click on to the options tab and then go to properties and after that in the mixer device select the first option or check the recordings options then check all of the options in the list then click ok you will get a new window which give you the option of unmuting the microphone.
Posted on Oct 29, 2009
  • 52 Answers
SOURCE: how to replace a cooling fan for Compaq Presario
I would definitely consider taking it to a certified repair shop first.
If you must do it yourself, get the proper fan, (Which you can find on ebay for around $22 new), a set of small screwdrivers, and preferably an anti-static wrist band. You will likely need to take out every single screw in the thing to get to the fan. It will be fairly straight forward to replace unless you need to take off the heatsink, in which case the following information may be useful. If you can avoid taking off the heatsink do by all means.
As with all electronics wash your hands first, touch a ground (Typically your sink facet is grounded), and stay grounded if possible (With the wrist pad), and avoid touching any chips as the oils from your fingers can cause problems.
And always take the battery out and make sure it's not plugged in before starting anything!
The fan itself has a 3 wire connector, and will simply screw into place on the heatsink.
If you do remove the heatsink from the cpu you may want some heat transfer goo .
Some heatsinks now don't use heat transfer goo any more and have a pink pad that melts at high temps which helps transfer the heat.
I prefer arctic silver for the heat transfer goo, and to remove the old heat transfer goo before adding the new. Place a very small amount on the heatsink, enough to cover the part it makes contact with and no more, being very careful to not allow any air bubbles, and making sure it's spread evenly across the surface. Don't use your finger, use a flat edge to spread it, Maybe a box razor blade or something similar.
If it uses the pink pad, do not put heat transfer goo on as when the pad melts the transfer goo will mix with the pad and degrade the performance of heat transfer. Ensure the pink pad is in the same place it was when you removed it.
Put back together, ensuring every screw is back in, then cross your fingers and toes.
Posted on Apr 18, 2010
No interneyt
Go to compaq.com. Click support. Enter in the search bar model number. Choose operating system. Download LAN driver and any other drivers you need.
Sep 20, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq presario v3000 internal microphone not working
hi
Sep 15, 2009 | HP Compaq Presario v3000z Notebook
I have purchased the compaq presario cq 40 315tu laptop its inbuilt web cam is not working i am using window vista O/S paras email: nimiwal_auditor@yahoo.com mob: 09911347435
If u r web cam is not working means it does not have suitable drivers for it....u download those suitable drivers and then install.....if not there must be some internal problem in u r laptop....apply for warranty
Reply if satisfies
Jul 04, 2009 | Computers & Internet
I have Compaq cq-60 leptop, it's microphone is not working, can u help me
Jun 26, 2009 | HP Compaq Presario CQ60Z Notebook
I have compaq presario CQ 40 317TU notbook. i want install windows xp in my notbook. Plz help for this
for XP OS make sure you have a copy of all your driver software so that you can install it after you install you XP if you don't have iinstaller of your laptop you can download the driver HERE
Mar 19, 2009 | Compaq Computers & Internet
Hp compaq cq 40 108 tu laptop can i get audio video drive
can i get solution to install win xp on compaq cq 40-108
Dec 09, 2008 | Compaq Presario Notebook
HP Compaq Presario CQ40-330TU Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
