Braemar paradigm evaporative cooler stops and wall control says "service" and shows fault code 2 when you restart it
3 Suggested Answers
  • 5 Answers
SOURCE: I have a Braemar LCB450-G
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Posted on Nov 26, 2010
hvac1960
  • 2133 Answers
SOURCE: fault code 049f,this fault shows
f-049 Check power supply voltage to the outdoor unit is correct (1ph ?220 Vac ±10% or 3ph ?380 Vac ±10%). If OK check fuses, if fuses OK, replace outdoor main PCB
Posted on Dec 13, 2010
What is a flashing 4
What brand is it. If its an evaporative cooler like breezair or braemar it means it is not draining the water. If so check the drain pipe and the drain valve
Sep 11, 2014 | Hunter Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
It starts running and after about 15 seconds it shuts down with a message of service then what i see as an alarm 7 and shuts down
If it is a evaporative cooler that is breezair, coolair or braemar it will be because it has to low or too high a voltage supply. another problem could be the capacitor is the wrong size
Feb 09, 2011 | Mastercool 67680 Evaporative Cooler Air...
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
Nov 22, 2010 | Heating & Cooling
Braemar cooler turns itself off after it has run for a while. Still operates on fan only
most likely has a gas leak and cuts out when the gas pressure drops below its' cut out pressure. nead to find leak and repair, then charge unit to running pressure
Apr 23, 2010 | Mastercool 67680 Evaporative Cooler Air...
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
