2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
The screen seems to want to play and displays the numbers for playing and ejecting but nothing plays or comes out. i could here the noise as if want to eject but no good what do i do.
  • derry johnson Dec 02, 2012
    i ulled the fuse out and put it back in. that didn't help. now there is no numbers or any thing indicating that there is even a cd player . no numbers for the 6 disk that are inside , no ejection display, basicaly like i do not have a cd player. when i push band it display dvd-x initializing. what does that mean ? i have never used the dvd player. what now? i guess i have to do what the other guy said and buy another with the USB and SD player so there is no disk at all.
    Sergeant:
  • 198 Answers
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Posted on Dec 02, 2012
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
  • 1003 Answers
SOURCE: Toshiba SD420e player won't play -drawer keeps ejecting
Have laser lens cleaned
Posted on Jan 17, 2008
  • 61 Answers
SOURCE: VCR WORKS,BUT DVD DOES NOT
Place a disc in the tray with the label facing up. Let it try to read. If the disc is still oriented the same way after it fails, odds are 99 out of 100 the motor has failed....sorry, buy a new one if warrantee has run out.
Posted on Feb 17, 2008
SOURCE: 3370 H player is 'blocked' cannot eject disk
en la parte inferior del aparato hay una ranura alargada. hay que mover el switc e inmediatamente se desbloquea.
araceli
Posted on Mar 28, 2009
  • 46 Answers
SOURCE: DVD won't eject from magnavox MWD2206
Do u see a small hole in the front plate of the dvd player?
if you do ur in luck, unravel a large paper clip to make it straight, then very slowly push it straight into the hole until you see the dvd open.
If no hole then u will have to open the case while it is unplugged.
Posted on May 24, 2009
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
BMW X5 Rear Entertainment System, center screen, player on center console floor. DVD discs cannot be read. CD's play fine. What is wrong?
A. Did you try a second disk to make sure the disk isn't bad?
B. Is the DVD a new format like HD, 3D or Blu-ray? if so it won't work.
Oct 06, 2014 | 2008 BMW X5
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Cadillac dolby sund system will not play or eject 2008 sts
the internal mechanism has died ,one of the plastic wheel has worn out ,just renew the player and get one with USB and SD card players then you will not need lots of CDs cluttering up your car
Dec 02, 2012 | 2008 Cadillac STS
I have a Zenith I played a dvd an it worked fine - put another movie in the dvd player and was going to watch that one and it never read - screen kept saying 'reading'. I tried another dvd and the...
try using a CD cleaner disk..
How old is the system?
DO CDs work when you try them?
Put a disk in... remembering the position it was in..
Then try to play the disk...
Eject if it does not play and look to see if it has moved to a different position...
If not, there is a motor problem or the laser is not sensing the disk being there.
Have you ever opened up the main box of the system?
Has anyone else been inside it?
If yes, then maybe it is time to do it again to observe if there is movement of the laser pickup..
Jun 01, 2011 | Zenith XBS444 250watt DVD/VHS 6-Speaker...
My Samsung HT-Z210 Home Theatre System is crazy. Sometimes it plays the disks but most of the times it would sound as if it is trying to load a few times and then displays disk error and if it does play...
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
Dec 03, 2010 | Samsung HT-Z210 Theater System
LG GP08 - SOFTWARE NOT WORKING
Try using windows media player or Real player to play a DVD and see if you get sound. If not try doing windows update <start> <program> <windows update> Updates usually fix that sort of thing. If nothing helps then look up on the web for DVD decoder for your Operating system.
Keep me posted.
Mar 13, 2010 | LG GP08NU20 DVD±RW Burner
DVD will not play just get a blue plus sign coming down the display after th DVD sign graphic. TV screen shows digital and no disc. Any ideas lease?
is it a burned disk? if so your dvd player might not be able to play that type of dvd... i know sometimes also scratched ones won't play at all as well... of course also make sure everything is plugged in correctly and if it does this with more different dvds then there's something wrong with the player itself... which i hope is not the case as those are very difficult to fix yourself
Jan 13, 2010 | Samsung HT-X200 Theater System
Mech Comm Error
sounds like they may have forgotten to take out transit plugs from radio which holds cd mechanism in place when shipping unless you got a new radio thats a dud? but that may also mean dealer didnt check operation of new unit after replacement if replaced which is what usually needs to be done when this error message comes up
Aug 06, 2009 | 2005 Jeep Grand Cherokee
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
