Question about Sewing Machines
Reverse button on janome my excel sewing machine not working
Unable to use the reverse button on the machine - apparently this a common problem with this particular model of janome machine. Have had it to the sewing technician twice now & want to know how to fix it myself.
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
SOURCE: Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Posted on Mar 02, 2009
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
SOURCE: Hi, Where can I obtain an Instruction Manual for
Go to the janome website
Click on country
Click on machines
Check either the home sewing/embroidery or retired section for your model
number
Posted on Jan 23, 2011
M Janome Excel 18W will not sew in reverse. Can I fix this myself?
if there is a reversing knob or button then a fix is possible
might be best to have it professionally serviced
Aug 07, 2016 | Janome Sewing Machines
Model 18w. Why won't it reverse?
If you read a little over halfway down the web page below, you will find another Janome with the same problem. Perhaps it will help:
Repairing Janome or New Home Sewing Machine
Janome New Home mx3123 reverse button not working
Dec 17, 2015 | Janome Sewing Machines
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
Jan 15, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Backward sewing machine
that sounds like the button is stuck. You may need to get it looked at.
Oct 23, 2008 | Janome D'cor Excel 5018
Sewing Machines Logo
322 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
