Question about Bosch HGS442UC Gas Kitchen Range
My oven wont light
I have a gas stove and my stove top and broil work fine but the oven wont turn on. I do not have my manuel as the oven was here when I moved in. This happened instantanoues. I used it in the afternoon (yesterday) and went to use it for dinner and it would not get hot.
The problem is likely a faulty igniter. It's an easy fix, though an expensive part to replace (about $75 from APP). I had the exact problem and found this answer on another site. Just check out your igniter (under the plate on the bottom of your oven.. remove the screws in the back and lift off that plate).. the igniter is a long flat piece that should be glowing red.. if not.. that's your problem. Good luck.
Posted on Mar 25, 2009
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Bake and Broil not working
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Model fgf337asa
Turn your gas knob to ON position. Let me know if it does not work,
Jul 16, 2008 | Frigidaire FGB24S5A Gas Single Oven
GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
May 21, 2008 | Kitchen Ranges
Bosch HGS442UC Gas Kitchen Range Logo
277 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
