Pioneer VSX-518-K Receiver Logo
Dennis Smith Posted on Dec 02, 2012
Pioneer vsx-518-k power problem
My Pioneer vsx-518-k will not power up,1 week before unit quit I had a problem with the remote turning it on/off.I would point remote at unit to shut it off and nothing would happen than 10 minutes later it would shut off.and then the remote would work fine.I had unit playing in my shop and went out and when I came back it was off.I checked fuse.disconnected speakers.still will not power up.
et r
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Dec 30, 2020
et r
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
1085
Points
Hi annon nick i tried your advice it works and it indicated AMP ERROR and it shutdown i tried again pressing the buttons and it turns on and i manually turned it off and turned back and now its ok but im afraid to use it with the soeakers cause it maybe worse...hope to have a promp advise from you...thank you and happy new year
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 49 Answers
  • Posted on Dec 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
49
Questions
0
Helped
17653
Points
75
Thyat is called the protection mode, There is a internal problem with it when they do that,
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 12, 2009
SOURCE: no power
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Anonymous
  • Posted on Dec 31, 2008
SOURCE: receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Michael Borelli
  • 979 Answers
  • Posted on Nov 26, 2007
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Gustavo M.
  • 30 Answers
  • Posted on Aug 02, 2009
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Anonymous
  • 1512 Answers
  • Posted on Nov 08, 2008
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
I have a rca universal remote need to get to work with pioneer av vsx1019ah
Just buy a replacement remote made for the device.
Remote Control - Pioneer VSX-1019AH Operating Instructions ...
www.manualslib.com > manual > Pioneer-Vsx-1019ah
Pioneer VSX-1019AH Manual Online: Remote Control. RECEIVER 1 DVD BD TV CD 2 iPod USB TUNER INPUT SELECT 1 SIGNAL SEL MCACC 4 3 SBch 7 ...
remote Control For Pioneer VSX-1019AH-K VSX ... - eBay
www.ebay.ca > ... > Remote Controls
Find many great new & used options and get the best deals for remote Control For Pioneer VSX-1019AH-K VSX-919AH-K VSX-01TXH A/V AV Receiver at the ...
Generic Remote Control Fit for VSX-1019AH-K ... - Amazon.com
www.amazon.com > VSX-1019AH-K-VSX-1019AHK-...
Buy Generic Remote Control Fit for VSX-1019AH-K VSX-1019AHK VSX-522-K AXD7536 7.1-Channel for Pioneer AV A/V Receiver System: Remote Controls ...
Pioneer vsx-518-k does not want to come out of standby
Try disconnecting all the cables from the back, including the speakers. Sometimes a short develops on an output stage. If the unit stays on, reconnect one input/output at a time, turning the unit off during the reconnection, to isolate the problem. If it does not stay on, it's an internal problem, requiring a service call.
2answers
My component pioneer vsx-518 has no power, what is the main reason and which item will i check?
• If you have a multimeter, check for DC outputs on the power
supply regulators, there could be some
• Or check for cold solder joints (if you can't find any)
diodes, capacitors or regulators
on the power supply.
• These could be just a power supply problem, main amp or both
Let me know if you need further assistance!
Was connecting subs to speaker connections when it popped, turned off and will not turn back on...VSX-518-k
You probably blew a fuse. It should be marked on the back next to where it tells you to turn the power off before connecting speakers.
Good Luck,
Gil
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
check audio ic & component like resistors & capacitors. good luck!
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
