Question about Water Heaters
Rinnai MC91Q2A HOT WATER SYSTEM HOW TO USE
HOW TO SET THE HOT WATER TO USE IN BOTH BATHROOMS
  • 234 Answers
SOURCE: I have a Rinnai system. Good cold water pressure, little hot.
What type of pipes are install on this heater?
Posted on Mar 13, 2009
gary1121
  • 332 Answers
SOURCE: I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Posted on Jan 26, 2010
pappapumpdaf
  • 635 Answers
SOURCE: We used to have hot extremely hot water in both
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Posted on Mar 24, 2010
Testimonial: "Thank you so Much!!"
senor8
  • 73 Answers
SOURCE: Rinnai Infinity 26 hot water system set to 55
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Posted on Aug 01, 2010
In temperature screen at 49 degrees to back to front t's appear and boiler stops
PDF]Operation and Installation Manual Outdoor Tankless Water ...
https://www.rinnai.us/.../U287-1932(00)_Outdoor_...
Rinnai America Corp.Temperature controlled continuous flow gas hot water system. .... This water heaterwill attempt to provide hot water at the temperature setting even when the ...
Hot water system temperatures and the code ' Plumbing ...
plumbingengineer.com/content/hot-water-system-temperatures-and-code
Feb 1, 2015 - There have also been incidents where the circulating pump stopped ...before it connects back to the cold water inlet to the water heater. .... Is there a maximum temperature limit for domestic water heaters? ... a means to limit the maximum setting at the valve to 120°F (49°C) or ... Some do and some don't.
[PDF]User's Operation Manual - contents - Navien
Dec 25, 2015 | Water Heaters
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Dec 18, 2010 | Rinnai Digital Remote Water Heater Control...
My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
Run through the basic checks
  • Power lead from the heater plugged in a socket turned on.
  • Gas on to house
  • All valves below heater in on position.
  • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
Sep 21, 2010 | Rinnai Digital Remote Water Heater Control...
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
-Faulty check valve
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
Nov 28, 2009 | Rinnai Water Heaters
My Rinnai 26 sometimes takes 10 minutes to start
This is not an uncommon problem. You may notice this problem particularly if you haven't used hot water for a period of time. The hot water heater is probably working, but there is quite a bit of water that has to clear out of the lines before the hot from the heater reaches your appliance. I suspect that the water heater is doing its job, and that is the assumption I am going off of for my next statement. A recirculation system will work well to eliminate your problem. Again, assuming that the hot water heater is in proper working order. I would do my research on recirculation systems before buying one. Often times you get get a relatively inexpensive unit that will do the job for you.
Nov 18, 2009 | Rinnai Water Heaters
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
Mar 13, 2009 | Water Heaters
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
Rinnai infinity hot water service, goes hot and cold...not fun in the shower!
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably machanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem,
Oct 20, 2008 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Water Heaters Logo
189 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
