Question about GE 27GT271 TV
Hooking up antena & converter box - GE 27GT271 TV
  • 736 Answers
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Posted on Dec 02, 2012
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
I have the converter box i have a plasma samsoung do i nstill need a antenna
Yes,u need a good antena,like a digital antena or a roof antena to recieve good free air DTV signal.U don't need a converter box,because ur tv is a digital tv.
May 04, 2010 | Samsung LN32A330 32 in. LCD TV
We unplugged out VCR, and now the converter box won't turn on. has power to it, but the little red light won't turn green.
plug your vcr back in, or undo co-ax cable from vcr and put antena wire to antena in on converter box and wire going to the back of tv to tv out on convrter box
Nov 26, 2009 | Insignia Digital-to-Analog Converter for...
I have hooked up my converter box but its not receiving any signal. do i need to buy a new antana? Or what could be the problem?
make sure u have the antena hooked to box and box hooked to tv, make sure antena wire is actually hooked to an antena if wire is coming out of the wall, otherwise u more than likely need a new antena, or box it's self is bad but if it turns on and u see somtin on the screen like make sure antena is hooked up then the box is probaly good
Nov 18, 2009 | Insignia Digital-to-Analog Converter for...
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
I have analog tv, combo dvd vcr and magnavox converter how can i conect them
Put ur tv in channel 3.Take the colax cable came with the converter box put it in the hole in the converter box said tv in the hole cocnverter box,the other end of the colax cable put it in the tv set hole said antena.Now take ur anatena signal an indoor or roof antena put it in the converter box hole said antena in the converter box.Turn on ur converter box power on go to menu use scan channels,u should ready to go, when the scan channels is finish.
Oct 21, 2009 | Televison & Video
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
GE 27GT271 TV Logo
188 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
