My sansui ctv-svb2108 is out of service because of problem with the memory ic-M2001.where cud i get an original one.pls hlp me
Where cud i get this programmed memory ic-M2001 so that the tv set works.if there is any sustitute of this ic pls specify it and where will get a new one
    Master:
  • 879 Answers
There will be a number printed on it. This number is important to note. Buy the same number. That is all.
Posted on Dec 02, 2012
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
  • 1694 Answers
SOURCE: how to fix
Temporarily unsolder/remove vol up/down tactil switches on front of circuit board.They may be sending unwanted signals to the microprocessor. Does set work normally now? 2)Try removing batts from remote.3)PVAT! Pull chassis, Solder any/all bad connects esp. regulator pins.4)Send in to shop for diagnosis.
Posted on Oct 01, 2007
  • 520 Answers
SOURCE: Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Posted on Oct 23, 2008
  • 520 Answers
SOURCE: New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Posted on Nov 04, 2008
SOURCE: i have a Sansui remote controland want to know if
Problem appeared to be with the remote,as the circuit board had some white powdery deposits on it.I got some isopropyl alcohol and a brush and cleaned the board.Seems to be ok so far
Posted on Mar 31, 2009
What is service mode sansui ctv k2k 21-v
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 18, 2014 | Televison & Video
21"sansui ctv.slim.standby.ac in but no light or no sound.
Main board fault. Check the main IC [system chroma jungle]. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 27, 2014 | Televison & Video
Will not hold channel memory after tv turned off and then turned back on - have to go through channel memory step each time
Sounds like a main system control memory IC fault. Contact any service technician, or the authorized service center for Sansui.
Gopakumar Gopalan Google
Mar 13, 2014 | Sansui HDLCD3250 32 in. LCD TV
I have a videocon ctv in that set there is a problem.the original ic is 8823cpng4rj1 is used. in this ic remote does not work.when i replace the ic 8823cpng5hk5 the remote is work properly,but the second...
Today videocon, akai and sansui are doing on a same platform. You need to go into the service menu, and change the remote options. If you wont be able to do this, then i suggest you to get a universal akai, videocon, sansui common remote handset and it ll work
Jan 17, 2014 | Televison & Video
Pls send me sansui model-s2s21,21"ctv
i had sansui s2s21 model the problem is that the its screen display is very dim. kindly give the solution.
Feb 26, 2011 | Televison & Video
In sansui television. is not working properly. in the remote. but front panel is working. i have changed the remote also . but problem remains. then i changed the sensor. it remains. then changed the...
dear,i also had suffer from it's service menu code. in some days ago i had been seeing a web site, their was had every service menu.then i got your sansui tv model.your sansui "ctvk2k21"model's in the IC no. is "tda9370ps/n3/a/1932" service menu is press "menu(from remote) & 0,3,2,3(from remote)".for more information call me for in any electronics gagged problem.
Aug 15, 2010 | SansuiM1315 TV
Spare parts for Sansui TV
Hello E.C. Wait
Your parts can be found simply on amazon, click here and take a look: Amazon com sansui tv parts. Wish you best of luck.
Donald
Nov 21, 2008 | Sansui HDLCD3200 TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
