Question about GE PDS22SIS Bottom Freezer Refrigerator
Refrigerator not cold
Hi, I have a GE Profile bottom freezer. My refrigerator is staying around 55. I have replaced the motherboard, but this just seemed to reset the defrost feature in the freezer (it was staying frosted). It doesn't seem to be the other circuit board at the top either. I have a repairman, but he is at a loss. He has suggested that we check the vents, but we have not done that yet because he doesn't seem to think that this is the problem. Could there be something else?
  • Anonymous Apr 10, 2009
    I also have a GE Profile Stainless Steel bottom freezer. I have a fan blowing in the freezer...that part works fine. Electronic display is working in the fridge, displays correct temperature, but fridge cooling unit doesn't kick in. Unit is less than four years old.
  • Ken Bledsoe May 11, 2010
    Can you answer a couple of questions for me. Check out to see if you have a fan blowing inside the freezer compartment. and also under the fridge down by the compressor do you have a fan blowing down there. ken
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
MNfisherman
  • 11896 Answers
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold air around in the freezer and blow the cold air from the freezer into the fresh food section, it also sucks the warm air from the fresh food section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
00082692.jpgEvaporator fan motor
Posted on Jan 21, 2009
michigan man
  • 3533 Answers
SOURCE: no ac from vents
you may have a vaccum line off under the hood of behind the a/c heater control unit itself i also would like to give you this information its Schram auto & truck parts 1-800-292-1032 and the website is www.schramauto.com if you every have a hard to find part they only sells GM- parts.
Posted on Apr 27, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
  • 1891 Answers
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Posted on Feb 04, 2010
Freezer cold, refrigerator sometimes cold sometimes hot
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | GE Profile Stainless Bottom-Freezer...
Top too warm bottom too cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 22, 2011 | GE Profile PDS22MHR Bottom Freezer...
Ge profile refrigerator/freezer, freezer on the bottom. Refrigerator stopped cooling.
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 06, 2010 | GE Refrigerators
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
The refrigerator will not stay cold set @ 37 and it runs and the freezer is -4
heatman101
Aug 22, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
GE PDS22SIS Bottom Freezer Refrigerator Logo
78 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
