Question about Toshiba Computers & Internet
I recently found out my toshiba laptops hdmi port has a plastic cover bcuz this model doesnt come equipped with it yet there is a spot that says hdmi and has a small plastic cover. if i remove this cover do you think the port would actually be there and usuable or no? someone please help
    Scholar:
  • 156 Answers
No. Plastic covers are made in common for the same series. If that part is covered with plastic, that means no HDMI connection. A motherboard service technician can sortout it for you.
Posted on Dec 02, 2012
5 Suggested Answers
  • 4 Answers
SOURCE: My laptop's HDMI port is stuck!
if you bought the same one as myself CQ50-110us then the plastic plug means you have no HDMI. look closer on the box or on the website for more info.
The "Begin Here" poster/quick setup guide states HDMI port on select models only. Same for having built in webcam
Sorry if you were expecting it to have it
Posted on Nov 17, 2008
Suraido
  • 195 Answers
SOURCE: Hdmi Port .
If the laptop has no HDMI port, the forget the whole HDMI thing cause getting it through that port when the laptop or desktop is not made for it will end up costing as much as a new computer altogether. You need to find out if the laptop has any Composite or Component outputs. Those are relatively easy to spot. a Composite output is usually a RCA jack and also usually colored yellow, and goes into the yellow RCA port on your TV next to the red and white RCA ports which are the left and right sound channels. The Component outputs are also RCA jacks, but are usually red green and blue cause each wire sends its own color to make up the TV's image. They will also go on the back of your TV near all the other RCA ports. Wether your TV has just HDMI and no other porte or not, or if it has either Composite or Component inputs or both, that i don't know cause i don't know what your TV is. As for the sound, if you also want it on the TV, you just need to go to the local electronics store and buy an adapter/wire that goes from a 1/8 stereo headphone jack to 2 RCA jacks on the other side, one being white and the other being red. See where i'm going with that?:P Plug the 2 RCA jacks from the wire you bought into the TV in the corresponding inputs that go with the input you plugged the image in, and the 1/8 stereo jack into the headphone output of your laptop.
Posted on Jul 08, 2009
  • 38 Answers
SOURCE: Toshiba Laptop wont work unless plugged in.
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
Posted on May 13, 2008
rajdeepdutta
  • 2517 Answers
SOURCE: acer aspire 6920 hdmi port
Just do 1 thing press in and leave the tray/ small botton. if done thumbs me.
Posted on Jan 30, 2010
How do I connect a external monitor to my toshiba P55T-B5262 laptop
Ok I looked at the Specs on the laptop --- you have a HDMI port --- Same thing found on almost all tv's now days
-you need a HDMI to VGA or an HDMI to DVI converter --- very inexpensive purchase
Options #1
If the monitor you are trying to has this port:
-then you need a HDMI to VGA adapter
http://www.ebay.com/itm/like/350902230382?lpid=82
Options #2
-then you need a HDMI to DVI cable
http://www.ebay.com/itm/HDMI-to-DVI-D-24-1-Pin-Monitor-Display-Adapter-Cable-Male-Male-HD-HDTV-6-FT-/141210464113
Hope this Helps!
Sep 06, 2014 | Toshiba Satellite Computers & Internet
I own a Toshiba Satellite C855D and my HDMI port has a plate cover. How do i get it off?
Are you sure you actually have a HDMI port ad not just the area that makes HDMI optional when ordering or for after the fact installation of a new video card?
Jan 12, 2013 | Toshiba Satellite C855D-S5354 15.6" Laptop...
Were are the hdmi ports on my toshiba c660d153
Your laptop does not have HDMI port only VGA, you have two choices check if your TV has a VGA port and if it does you can connect the laptop to the tv (you will need a vga cable.) if tv doesnt have VGA connector then you could try finding a USB to HDMI adaptor for example:
http://www.cooldrives.com/index.php/usb-hdmi-adapter-dvi.html
Jan 11, 2013 | Computers & Internet
Is there a cover over the hdmi port on the toshiba C855D-S5359
According to Toshiba Website - there is no HDMI port on this model laptop.
http://us.toshiba.com/computers/laptops/satellite/C850/C855D-S5359/
Dec 30, 2012 | Toshiba Computers & Internet
Does toshiba satellite m505-s4940 come with hdmi port
Quoted from CNET review:
"A full-size ExpressCard slot and a memory-card slot are all welcome features, but HDMI has been dropped in the S4940--a plugged-up port is all that remains. "
Sorry...
Nov 21, 2012 | Toshiba Computers & Internet
Does Toshiba L655 s5072 has HDMI port?
Welcome to Fixya.
This Toshiba model does not have an HDMI port - you may follow the link below for more details surrounding this system :
Toshiba Full specs
Thanks for using Fixya.
Jul 04, 2011 | Toshiba Satellite L655-S5072...
I cannot stick a hdmi chord in the hdmi port it is blocked and cannot not be open by hand how do I open it
Your computer may not actually have an HDMI port. The spot you are referring to is most likely where to manufacturer puts an HDMI output for higher model laptops.
Jan 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
Acer aspire 6920 hdmi port
Nov 12, 2009 | Acer Aspire 6920 Notebook PC
Nov 15, 2008 | Computers & Internet
Upgrading Ram on my Toshiba A135 S2386 Laptop, still under warrantly
Hi there. There are 2 locations on the border of the plastic cover, both on the same side. You need to use a small flat screwdriver or your nail, and lift the cover using those 2 spots. It will snap out of place ! If you hold the laptop upside down, the front of the laptop closest to you, the 2 places where u need to lift are on the right side. You need to lift on that side, and the plastic latches are on the left side only. Hope you see what i mean ! But basically, lift right side. Thanks ! cheebster.
Jul 09, 2007 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
2,725 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
