Question about Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive
Hard drive wont recognize. This device cannot start. (Code 10) error
Hi, I'm having problems with my toshiba external hard drive (320gb). I accidentally removed the usb cable from the PC without using the "Safely Remove" option. Now it doesnt work, PC cant recognize the hardware. I tried different fix already: Uninstall from "Device Manager" Connecting it to a different USB ports and different PC/Laptop etc. Also tried searching drivers from the net, still doesnt work Please help! Thanks!
  • 236 Answers
SOURCE: External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
Posted on May 08, 2010
virtualhost
  • 2185 Answers
SOURCE: I have a 320gb toshiba
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Posted on Jan 13, 2011
  • 240 Answers
SOURCE: I have a toshiba canvio 320GB external hard drive
Hi. Thanks for your question.
  • Here's what else you can do.
  1. Check the USB cable. Make sure it's connected securely. to make sure test with other device or computer to determine that cable is OK.
  2. Once you know you are using good cable you need to make sure that Hard Drive isn't at fault. Trying to use it in other PC is the best method of making sure that everything is OK with it.
Do not hesitate to come back and ask more if none of these solutions helped you. I am sure one of FixYa expert's will be able to help you.
Thank You for using FixYa.
Posted on Jan 17, 2011
shibuda
  • 1812 Answers
SOURCE: When I connect my Toshiba
Please setup your bios as LOAD FAIL SAVE DEFAULT or you can set in manually,
Follow the bellow link.
BIOS SETUP BOOT CD YouTube - Acer aspire 5580 Main Unit Disassembly.flv Repair4Laptop: Laptop & Notebook Repairing, Upgrading and Modding Guides: by Manufacturers http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ Laptop Parts 101 CD-Rom support from Bios Phoenix BIOS setup and help BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2 It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my computer>properties>hardware>device manager, and look to bottom of the list to USB Controllers.
right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed automatically.
Go back to the controllers after restart and ensure there are no'!' marks or no 'X' against any controllers
or
It can Also fails, you might have a problem with your bios. You might want to update your bios (but of course this involves some risk).
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Posted on Jan 25, 2011
  • 1768 Answers
SOURCE: Toshiba MK6025GAS HDD (External) not recognized
from what you have written it seems that the Hard Drive is dead and doesn't have the ability to read the drive.
You will need a new hard drive this one is not recoverable.
Posted on Nov 29, 2011
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Help
What operating system do you have?
Thanks,
lee
Jun 24, 2008 | Western Digital 320GB MyBook External USB...
I can't Open my External Hard Disk Buffalo HD-PXT320U2/W-AP .. How can i solve this problem .. ?? The Interface view I/O Error Device .. Thamls for yOur hElp ..
I/O Error Device means that the pc cannot communicate with your external HDD - either the USB cable is broken (replace it) or its control board has failed. If it's the latter then the Buffalo is dead, get a new one.
May 24, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
When i plug my simpletech hitachi 320gb black cherry hard drive into my laptop the light comes on on the hard drive but my computer doesnt find it, went into device manager and it says the device wont...
i,m not a big fan of simple tech do to the fact that they sell cheap products and 9 times out of 10 they fail mechanically you can try and format to see if that works
Mar 23, 2011 | SimpleTech Signature Mini 320GB External...
I have a toshiba canvio 320GB external hard drive which I have been using with Windows 7 with no problem. Now I get error message USB device not recognized. I have tried shutting down the computer, what...
Jan 17, 2011 | Toshiba Canvio Plus 320 GB 2.0 Portable...
MyBook WD external HDD Code 10 error
If you have tried the device in 5 different computers and it has the same problem the the problem is with the device. You might want to try and dis-assemble the hard drive case and try installing it directly into the computer to make sure the drive is working properly and to recover you files. If the drive is working then the problem is with the device interface that is built into the case or the built-in power supply.
Dec 01, 2009 | Western Digital My Book Essential 1TB...
I/O Magic 320GB external hard drive making clicking noise
it happens when the hard is gone bad or can`t be recognised.you can try uninstalling the drive from device manager.you can check the hard drive case or can try the hard drive on some other computer.
Jul 08, 2009 | Computers & Internet
When my simpletech 320GB External Hard Drive starts up, it starting clicking, and won't be recognized by my computer.
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 05, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive Logo
211 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
