Question about Nokia Classic 2700 Cell Phone
Phone shows no sim card inserted
Phone does not accept sim card and shows no simcard , start without simcard
    Master:
  • 368 Answers
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Posted on Dec 02, 2012
Sheruraj
  • 72 Answers
SOURCE: The phone will display no SIM card inserted
Format ur Mobile -
Posted on Jan 14, 2009
  • 229 Answers
SOURCE: i have nokia x3 with
Try the sim in another phone and another sim in your phone. What I see is either the sim is bad, or the phone is rejecting the sim. In either case, you would have to call your mobile sevice operators and alert them of the situation. They would help you further. Hope this was helpful?
Posted on Mar 25, 2011
  • 43 Answers
SOURCE: MY NOKIA 6300 IS SAYING 'NO SIM CARD INSERTED', BUT THE SIM CARD IS INSERTED. WHAT CAN I DO?
no problem.. jus remove your sim card and reinsert it. .sometime it may happen like this..
Posted on Sep 06, 2008
  • 272 Answers
SOURCE: Phone not accepting a new SIM card
I think you have activated this sim only lock. This should be found under security menu. Try unlocking i first. If none works, you may consider flashing the phone if you need the phone working.
Posted on May 27, 2009
  • 6 Answers
SOURCE: Nokia 6300, simcard is not detected.
Insert the sim in it dear it will necer ask it again
Posted on Aug 02, 2009
Start up phone without simcard?
I am using nokia 2700 classic mobile, some times it shows no sim card available in display. so i switch off my mobile to switch on means it shows Start up phone without simcard?
Apr 30, 2012 | Nokia Classic 2700 Cell Phone
Not accepting any sim card and show error "start
You phone fails to recognize,the a look at this causes,might 1 of the problem is listed below.
(solutions are already indicated).
* your simcard might be corroded and need to be clean using a pencil eraser.
* simcard socket lock might be losen and need to bend a little bit downward to reach the contact of the simcard.
* simcard reader or terminal pins is dislocated and not properly align,need to fix in proportion or re-aligning.
* simcard reader or terminal and its pin is corroded and need to be clean using any rust solution and a cotton.
If the above method does not work,simcard IC might be damage and need a parts replacement,by this time,you need to bring it to the service center to fix this problem.
Aug 03, 2011 | Nokia 5220 XpressMusic Cellular Phone
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
Insert sim
ya.. when you start the phone without the simcard it shows "insert sim"..
you have to insert your sim at the back of your mobile phone.. For inserting sm read your manual which comes with your phone..Then start the phone..
hope ,it solves the problem
Apr 17, 2010 | Motorola Mobility RAZR V3i Cellular Phone
My nokia 3200 restart when simcard inserted.but when simcard no inserted the phone no restart.just showing insert simcard
Hi
This is happening because when the Sim card is not inserted you cannot access the menu of the phone some nokia phones(including yours) are built that way.
Some nokia phones do not need a sim card for you to access the phone menu (e.g 5130,5230), while you can only view the demo of some nokia phones (e.g 1208, 1600) without a sim card
Mar 12, 2010 | Nokia 3200
PUK and PIN code for a Samsung SGH-A117
Samsung D500
Switch phone on without sim and enter :-
#*7337#
if it does not work then you need a direct unlock in a shop
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another Simcard. Turn on. The code is 00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
*2767*3855#
*2767*2878#
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
Jan 19, 2009 | Cell Phones
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
I phone no sim
try removing the simcard from the iphone by inserting the end of a paperclip into the small hole at the top of the i-phone, this will push out the simcard. Then clean the simcard and re-insert it into the phone, the issue should now be resolved. if it persists then it could be because you have a faulty simcard in which case take your i-phone to your nearest apple/o2 store and they should give you a replacement.
Feb 24, 2008 | Apple iPhone Smartphone
Nokia Classic 2700 Cell Phone Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
