Question about Home Security
Auto feature on white-rodgers thermostat 153-7758 not working properly
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: I have a White Rodgers thermostat series 1F78-151
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to cool then and lower the setpoint below room temperature. There may be up to five minute delay before the thermostat clicks in cooling. If the thermostat click this means its not a thermostat you have a problem with your cooling equipment call your installer. If the thermostat did not click the unit should be replaced.
Posted on May 26, 2010
liteswink
  • 99 Answers
SOURCE: need the wiring manual for a White Rodger
Please call the hometechline at 18002842925 to ask for a copy to be send to you, be ready with a valid emial address.
Posted on Jun 26, 2010
  • 8 Answers
SOURCE: Need instructions or manual for a white rodgers
Manual found here in PDF.
http://s3.pexsupply.com/manuals/1253196590775/17499_PROD_FILE.pdf
Posted on Nov 23, 2010
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
I have a w-r themostat and i can not turn the fan off. the ac is off and the thremo is off but the fan keeps running. how do i turnit off.
If you open the bottom swing door you will see a switch on the left that says Fan On/Auto. Make sure it is in the Auto position and the fan should cycle on and off with the equipment.
Tim Burke, White Rodgers Employee
Email me with further questions at tim.burke@emerson.com
Aug 19, 2010 | White Rodgers White-Rodgers 1F85RF-275...
On my white rodgers thermostat 1F80-361 air and heat wont work
Mine is doing the same thing!! My daughter and I are FREEZING!!!
May 23, 2010 | Heating & Cooling
We changed the batteries and now it appears we cannot get the panel to work in terms of turning on the heat. We would like to troubleshoot.
After you changed the batteries of your thermostat you need to reset the unit to operate properly. You may call homeowner techline at 18002842925 they will assist you if the above procedure did not work.
May 09, 2010 | White Rodgers White-Rodgers 1F85RF-275...
1f97-371 thermostat..how to lockout so only those asigned can make changes. no manuals on site. glenn
Features:
? Wireless Remote
? Universal Application
? Prioritize Between Thermostat & Sensor
? Average between thermostat and Sensor
? Sensor Display and Adjustment
Benefit:
? Saves installer time
? Less to carry and stock
? Minimize Hot & Cold Spots
? Less Sensors to Install
? Convenience & Control
Mar 30, 2010 | White Rodgers White-Rodgers 1F85RF-275...
IF81-261 TO MAINTAIN 76 DEGRES JUAST SET ON AUTO AND 76 IS THIS CORRECT ITS IN A BAR ? DO I HAE TO PUSH HOLD WHEN THE SPACE GETS TO 76 DEGREES ?I DONT WANT TO USE THE CLOCK SETINGS AS THE HOURS ARE...
First of all this thermostat doesn't have a auto change over feature.
To maintain the desired set point of 76F, is press first the system button to the system that you want either heat or cool and the next step that you need to do is to navigate the UP or DOWN arroes for your desired set point and It should follow that temperature permanently until you cjnage it again.
Aug 08, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
162 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
