Question about Samsung ML 1610 Laser Printer
Cover closed but computer detects otherwise
The printer unit fell to the floor when someone accidentally toppled it. the cover flew off then we attached it again. we managed to close it but when we switched it on, the computer says, please close the cover. is there any way we can fix this problem?
thank you in advance.
ling
  • gorgeousubbi Jan 12, 2009
    thank you so much for the prompt response. we'll follow your advice. More power!
  • 41 Answers
There is sensor beside this cover ,surly its broken then you can : repair with new sensor or unplug the wire with this sensor..
Posted on Jan 12, 2009
Got a broken piece from dc25 wand locking mech plus a small clear plastic clip,how does it go back together.It was open to use hose when it toppled over and fell.
Hi there, it's Jack at Dyson.
In order for us to determine exactly which piece has broken and how to resolve this, we would need to take some further details when you have your DC25 easily to hand.
At your earliest convenience, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or replacement part is needed, we should also be able to confirm if this would be covered under the Dyson warranty.
We'll look forward to speaking with you.
Sep 26, 2014 | Dyson DC25 All Floors Bagless Upright...
Why I got the message "close cover - upper cover open" ?
There is a sensor on the front left side usualy that detects the cover open or closed state. Check it maybe you made a mistake at assembling it or something came in between and the sensor can't detect it.
Aug 30, 2014 | OKI B4600 Laser Printer
Lexmark X1270. The paper goes to right and can not feed to print.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X1270 All-In-One InkJet Printer
Hello. I have a Lexmark x4650 printer/scanner/copier and the paper starts to feed thru and then pulls to one side. I am then unable to print my document. Why does this keep happening and how can i solve...
Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects that might have accidentally fell into it. If feeder is clear, open the printer cover and remove the cartridges. While the printer cover is open, check inside for any obstructions in the paper path. If none, then close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Close the cover. Load some paper (avoid overloading). Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jun 21, 2011 | Lexmark X4650 InkJet Printer
My printer is continuesly telling me that i have a paper jam , which i dont & im unabe to print what im doing -____-
my printer X5470 is telling me that I have paper jam, which I dont im unaba to print,what im doing
Jun 14, 2011 | Lexmark C533DN InkJet Printer
Our lexmark 5400 series printer fell on the floor. We put it back together but now it says cover open even when it's not. Not sure how to fix this problem.
Try to remove the sheets of paper from the feeder. Open the cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges and make sure they are properly seated and secured. Close the cover. Load some paper. Try to print again. If problem continues, please contact Lexmark technical support for additional assistance.
May 03, 2011 | Lexmark X3470 All-In-One InkJet Printer
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
Jul 08, 2008 | Office Equipment & Supplies
Roller Fell Out (with my help)
Pick up the printer, lay it on its front and close the reg cover. Simple as that but it took me ages to figure it out!!!!
Jan 22, 2008 | Dell 3100cn Laser Printer
Laptop fell on the floor (2ft drop)
Take it to someone that can disassemble it and repair the short at the jack - The jack probably got pushed into the computer when it fell and shorted. Typical repair cost at most shops is $100-$150 (although your might be more because of the short).
If you can disassemble it and take just the motherboard in to a shop labor should be a lot less since you will do 1/2 the work.
Get a recommendation for a place if you can since there are some places that are not very capable at soldering.
Oct 30, 2007 | Gateway M305CRV Notebook
Samsung ML 1610 Laser Printer Logo
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
