We are having a similar problem with our Mitsubishi > WT-46807 46 in. Rear Projection Television tv. It is approximately 7 years old. We used it for 4 years then moved to a new house and stored it in the basement (covered and unused). We just started using it again in the past few months once our basement was refinished (but very rarely, except for with the new guitar hero game since x-mas). It seemed to be working fine, then one day when we went to turn it on there was no picture or sound. The green light on the power button does light up and there is a humming sound, but nothing else happens. Can this be the same problem as you recommended to the last guy? The voltage regulator? Is that something I can replace myself? How? How much is it to buy? Is there anything else I can check? Is it worth fixing or should we just buy a new tv?
For this set you have !!
wow do this for me OK
with the set turned off press INPUT and MENUE on the front of set.
now count the flashing led.
it will pause for a secon number count on error code
like one blink then fast two blink this is a error code of 12 meening set is ok but then ther are manny other codes.
i need the code to help you out.
thamks,
daniel.
