Question about Kenwood KDC-138 FM / AM Receiver
What is the blue and yellow wire on the wire harness for the kenwood kdc-138?
I have a 1997 dodge dakota, and I'm trying to hook them up. But this blue and yellow wire is confusing me.
  • 1,975 Answers
According to any wiring diagrams I have looked at for the radio in your vehicle (both the premium and base systems), the only wire that I see that could get pretty much anyone confused unless they know is a dimmer wire coming from your headlamp switch. The only reason I cannot be 100 percent sure is because according to the wiring diagrams it is a black and yellow wire but I don't see any other wire with yellow that could cause a question. To be sure you can always check at the connector on the headlamp switch and check for continuity but if I were a betting man I would put my money on this. I went on and gave you the wiring diagram for the base system (without an amp). Not sure how well you can see anything due to a size limit on pictures but I hope I was able to help.
what is the blue and yellow wire on the wire harne - 12_2_2012_12_51_24_pm.jpg
Posted on Dec 02, 2012
  • Gene Casivant Jul 03, 2013
    The yellow is a memory which would be low but constant amp. Power. The blue is a remote wire for a amplifier if not useing one just cap it off good luck
SOURCE: Kenwood stereo Won't turn on
look and see if there is a reset... usually a tiny hole you can push a pen point into...(lightly)
Posted on Feb 15, 2008
merle840
  • 113 Answers
SOURCE: kenwood kdc-415s
if there is no amplifier separate from the radio - the blue /white wire from the back of the radio goes to the solid blue wire on the harness attached to the car's plug. the orange wire is not supported by the kenwood radio, so make sure you tape it well- if your not using a separate amp also tape up the blue/white wire coming off the harness you have coming out of the harness to the car. if this helps you please give me a good rating- if not please e-mail me at Merle840@aol.com respectfully M. Merle
Posted on Oct 13, 2008
  • 24 Answers
SOURCE: need color codes for a kenwood kdc- 122p head unit in dash.
Generally you can find these manuals freely available at the manufacturers website, however it usually take ages worth of searching and i thought id save you the hassle,
Head to this link for your units entire manual.. Page 17 i think it is exactly.
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
There a good little unit but sold a few when i was working in the industry.
Otherwise generally you can pick up pre wired pugs that adapt the cars harness via one plug to the back of the stereo avoiding any splicing. If youre interested in them head to this website,
http://www.aerpro.com.au/contents.php?menu=Harnesses
Hope this helps,
Have a happy easter
Cheers
Steve
Posted on Apr 03, 2009
etirbynnor
  • 655 Answers
SOURCE: What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
Posted on May 21, 2009
jaa278
  • 65 Answers
SOURCE: Kenwood KDC-135 remote wire
should be a solid blue wire
Posted on Jul 24, 2009
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Have a kdc-138 radio which wire do i attach the remote wire to get power to my amp
hi robert, attach your remote wire from the amplifier to the blue/white striped wire of the harness of your kenwood unit. the wire should be labelled "p.cont". cheers!
May 22, 2012 | Kenwood KDC-138 FM / AM Receiver
What color wier do i hook up my amp to the head unit?
The only wire that you should hook up from the amp to your head unit is the remote power wire which is the blue wire on the wiring harness for the head unit. Sometimes they are blue with a white stripe. Hope this helps.
Jul 10, 2010 | Kenwood KDC-MP235 CD Player
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Kenwood kdc-415s
Oct 13, 2008 | Kenwood KDC-415S CD Player
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
Jan 27, 2008 | Kenwood KDC-MP205 CD Player
Kenwood KDC-138 FM / AM Receiver Logo
212 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
