Question about Microsoft Xbox 360 Console
How to connect xbox360 to internet with laptop
    Scholar:
  • 53 Answers
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
_____________________
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
_______________________
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
______________________________________________________
Hope this helped, see ya' later. :)
Posted on Dec 03, 2012
  • Nate Sprague
    Nate Sprague Dec 03, 2012
    Note that the blue wire is an Ethernet cable.
Tip
Connect your 3g mobile broadband to an xbox360!
Have you ever wonder if you could connect your 3G mobile broadband modem to your xbox360? Well i have done it and it works fine.
What you will need to do is enable network sharing in your laptop/pc
I am using a vista laptop and orange mobile boradband, and this is how i done it!
First of all connect your 3G modem to your laptop/pc as you normaly would. Now get an ethernet cable and plug this into your laptops ethernet port and then into the back of your xbox's ethernet port.
Click on start> connect to> Then you will see "open network and sharing center" Click that. In the next window you will find all networks connected to your laptop/pc. You will see one below your normal internet connection called unidentified network. Click "view staus" Now in this window click and go to properties. now in this window click on the network tab at the top of the window. While now in this window click on enable network sharing via this device. Now go to your xbox360 and try to connect to Xbox live if at the first atempt it did not work test your connection via xbox as it will ask you to do this anyways. You should now be eable to connect to xbox live using your 3G modem.
Hope this helps!
on Dec 28, 2009 | Computers & Internet
I cant connect my xbox live using a cable connection from my xbox to laptop how do i get the connction
That would actually be a "Line" connection. Or "Link". You will have to use a cat5 cord, and connect it to your internet source. (NOTE) just because logic says you can connect a laptop or pc to your Xbox360, simply because they use the same cords, doesn't mean it works that way. You can however use your laptop as a "Media server" in direct connection. This only allows you to transfer music and movies from your laptop to the 360. Not an internet pass through. Sorry.
Jul 16, 2014 | Microsoft Xbox 360 Console
Setup xbox360 to internet with laptop
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 02, 2012 | Microsoft Xbox 360 Console
I dont now how to get my xbox360 to play xbox games
The XBOX360 requires a update file for each XBOX game to play on it. Not all games are supported. If your XBOX360 is connected to the internet it will automatically check for an update when a XBOX game is inserted. If your XBOX360 is not connected to the internet then you can burn a DVD or CD rom from a computer with the update files and insert the disc into the XBOX360 and update the files. Or you can load then to a USB jump drive and plug the jump drive to the USB port on the XBOX360 and update from that. The details are available from here http://www.xbox.com/en-US/support/systemuse/xbox360/console/systemupdates.htm
And remember not all XBOX games will play on the XBOX360. Only ones with updated files. So if it does not play after the file update then it is not supported. Microsoft updates these files quarterly so check back once a month for more updates.
Jun 26, 2010 | Microsoft Premium System for Xbox 360
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Is it possible for xbox360 hdmi to connect to the hdmi of laptop?
If there is the same number of pins and you can find the drivers for it than it could be possible.
Jun 11, 2009 | Microsoft Xbox 360 Elite Console
I need an IP adress
u have to change ur sharing settings on ur laptop in connections so ur port will open to let ur laptop and xbox find each other
Jan 06, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
52 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
