Question about EliteGroup ECS P4VMM2 Supports Intel Pentium 4 Processor (ECSP4VMM2REV81) Motherboard
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
From 256 to 1gb ram can upgrade is possible
  • EliteGroup Master
  • 3,606 Answers
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Posted on Dec 02, 2012
compdoctor20
  • 172 Answers
SOURCE: Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Posted on Nov 23, 2008
wayneard
  • 1901 Answers
SOURCE: can i install 1GB ddr2 on P4VMM2 Motherboard?
This is from the www.crucial.com website for your motherboard:
"Each memory slot can hold DDR PC3200,DDR PC2700,SDRAM, PC133 with a maximum of 1GB per slot."
It does NOT use DDR2. You can go to the crucial site and run a scan on your system. It works pretty well.
Also you can use a video card with a PCI or 4x AGP interface only.
Posted on Mar 23, 2009
rustysheriff
  • 344 Answers
SOURCE: I have an ECS P4M800-M7 motherboard using Celeron
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Posted on Jun 13, 2009
  • 117 Answers
SOURCE: Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Posted on Jul 12, 2009
map9966
  • 2351 Answers
SOURCE: 2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Posted on Jun 02, 2010
Testimonial: "Mike answered all my questions and very quickly. Thanks Mike. "
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
i think u are trying to upgrade ur ram with ur existing ram, if this then plz check ur old ram frequency and then select another ram with same frequency, means u have to install rams with same frequency. i hope u can understand what m i saying.
Nov 07, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
I have 256 MB RAM which is slow, can i upgrade it to 512 MB RAM
Depends completely on what motherboard the computer has and what it supports, I could check on it if you have and brand and model of the computer, or from the motherboard.
Sure the prosessor speed doesn't affect the memory amount possible don't worry about that, just need to find out how much is supported and at what speed etc.
Thanks,
Ekse
Jun 03, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Can i upgrade this with 1gb ram?
Hi again!
Yepp, you can upgrade it to 1GB memory
This is the spec of the memory on your 2055:
Memory RAM Technology DDR2 SDRAM Max Supported RAM 1 GB RAM Speed 533 MHz Installed Cache Memory 1024 KB
Good luck
Nic
DONT forget tp RATE me
Apr 07, 2009 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
Critical after DDR333 upgrade
cadyshack,
I got your latest version (8.1) motherboard on my screen & ECS shows your board does not support PC2700, only PC2100.
Downloaded your manual to verify this.
Notice you started having problems after upgrading RAM.
Link to your manual:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=436&DetailName=Manual&MenuID=7&LanID=9
This motherboard accommodates two 184-pin DDR DIMM
sockets for up to 1GB memory. Supports PC2100/PC1600
unbuffered non-ECC DDR DIMMs.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=548&Nav=|c:147|&Sort=0&Recs=10
Good Luck!
Mar 18, 2008 | EliteGroup P4VMM2 Motherboard
Possible cpu upgrades for p4vmm2 motherboard
I see that you have already had this answered at Techspot.com They were right when they answered you, you need to check your MB manual to see if it is capable of upgrading to the CPU that you want to use, not all MB support all CPU's just because they both have 478 pins. I looked on the ASUS website and they don't even list your MB model on there.
Mar 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
EliteGroup ECS P4VMM2 Supports Intel Pentium 4 Processor (ECSP4VMM2REV81) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
