Question about Sony DVP-SR320 REGION FREE DVD PLAYER
The player won't eject the disc inside ... It displays Locked ... How to unlock ??
I have tried Return, Enter, Power also Stop Eject for more than 5 seconds
3 Suggested Answers
  • 11800 Answers
SOURCE: Sony bravia DVD disk won't
Mechanical failure of the tray's mechanism - the clicking you hear is made by the wheel on the motor of the tray skipping over its eject lever.
The mechanism will have to be extracted from the tv as a whole then dismantled to see if the wheel can be reattached to the lever. If that is impossible (both plastic parts have been damaged) then the entire mechanism is dead and it will have to be replaced.
Since this is a brand new model and you bought it a few months ago it means that it's still in the warranty period. Because of that the entire repair/ replacement of the BR unit will be done for free by the dealer. Under no circumstance you should attempt to fix it yourself - opening the tv or forcing the unit will void the warranty.
Posted on Sep 15, 2011
SOURCE: My Sony DVD Player DVP SR320 won't eject ... Locked is displayed in screen .. Kindly help ... the DVD inside runs well
Hold down the play button, it will take a bit but it turns of the child lock
Posted on Feb 27, 2013
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
I put in a dvd into the dvd player, and went to eject it. I pressed the eject button and a "locked" caption came up on the screen. I dont have the owners manual and I cant figure out how to...
You may have enabled the child lock feature, try pressing the Return, Enter and Power buttons together to toggle the lock off. If this is disabled and you still can't open the tray, turn off the unit and unplug it. After 30 seconds or so, plug the unit back into the electrical outlet. Attempt to open the tray. If this does not solve the problem, try pressing Power + Stop + Eject buttons together. Also try pressing Disc1 + Stop + Eject simultaneously (if a disc1 button is on the remote or player).
If the error message is t - L C K or persists after trying all of the above steps, then you need the unit serviced.
The manual is available at the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPSR200PB .
I hope this helps.
Apr 16, 2011 | Sony DVP-SR200P DVD Player
How to correct the 5100 warning on the canon MX 310 printer.
Follow these steps:
Oct 06, 2010 | Canon PIXMA MX310 All-In-One Printer
Turn on machine and the check printer comes up on screen and the number 5100, also the on/off light and alarm light blink back and forth.
Follow these steps:
Sep 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
Wii system will not eject the game. The botton will not move
Hello! I will try to help you the best I can!
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet and wait 15 minutes.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform...
If all that doesn't work, there is a (not recommended) way to get the game out, but it will not solve the eject button problem. If you have any other questions, please do not hesitate to hit my "Ask Me" button.
I hope this helps you out. Good luck to you.
Jul 03, 2008 | Nintendo Wii Console
Error U99 disc stuck in machine
Neat Things
I have also discovered a number of special things you can do using special key presses. These have not been documented in any of the user manuals. As an aside, one time I was trying to manually set the clock. There is an automatic clock setting mechanism, but it's never correct. Even if it is, if the program you are recording starts 1 second early, it looks like it started at "8:59 pm" instead of "9:00 pm". The way I set the clock is 30 seconds before the top of the minute (At exactly 30 seconds after 9:00, my clock goes to 9:01). This way, you will have a ±30-second window at the top of the hour to get the time-stamp correct. At any rate, I was trying to set the clock manually, but that function was "grayed out". I tried the "Reinitialize Settings", but that didn't help. I tried to change the TV-Guide settings, but that didn't help either. I tried to switch between cable and TV, but that didn't help (and somehow even that became grayed out). I called Panasonic Tech Support. I was told that my system RAM had gotten corrupted and I had to send the unit in for service! This made no sense to me. I asked her if there wasn't a way to clear the RAM back to some starting point. I was told there wasn't, and please send the unit in for service. Well, as it turns out, there IS a way to do that! (See Commands) Another time, I (somehow?) managed to make the DVD Drive tray "Lock". If I tried to eject a DVD, it would display "LOCK" and refuse to open. At least this time, when I called tech support, I was told what to do - but it really should have been in the manual.
Commands
To toggle the disk eject from "LOCK" to "UNLOCK": With the unit ON, press and hold "Power" and "Stop" for 5 seconds.
To eject a disk if the unit won't operate (U99, etc.): With the unit OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
To enter "Service Mode": With power off, press "Stop" and "Time Slip" and "Open/Close" for 5 seconds. "SERVICEMODE 00" is displayed.
What follows are the more useful commands you can perform. You use the remote to key in a 2 number value. You can usually return back to the "Service Mode" by entering "00". If you get stuck, hold the power key for 10-12 seconds or until the unit shuts off. Try to avoid unplugging the unit while in service mode. In fact, because losing power while writing to either the hard disk or a DVD-R or DVD-RAM can lose everything, I use a small "UPS" (Battery backed-up Power Source) to power my units. This way, if the AC Mains go out, I don't damage anything…
Oh, and DO NOT experiment with any number combinations that aren't documented here. If you do, you may wish you hadn't…
00 = Return to Service mode start.
02 = Display Firmware Versions. The display will show the following for 3 seconds each:
1. DVD Region Code (should be Region 1 for USA)
2. Main Firmware Version (0950DL, or something like that)
3. Timer firmware Version (0110DC, or something like that)
4. DVD Drive firmware version (J125, or something like that)
5. ROM checksum (I think) - It should be all zeroes.
The ROM checksum will remain. You can get back to Service Mode with 00.
41 = The number of hours the laser in the DVD drive has been active.
51 = All display segments are turned on. Use 00 to exit.
61 = Date the unit was manufactured. YYYYMMDD
To exit Service Mode, hold the power key for 10-12 seconds until the unit shuts off.
Jun 20, 2008 | Panasonic Televison & Video
Wii
hello micky1965
1. Unplug Wii from power outlet.
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Sony DVP-SR320 REGION FREE DVD PLAYER Logo
18 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
