Question about HTC 7 Surround Cell Phone
My htc 7 surround keeps restarting itself. I've tryed hard reseting, leaving the battery out for an hour and it keeps restarting.... how do i get my baby back to norm???
    Master:
  • 368 Answers
MY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Posted on Dec 02, 2012
Shahrez
  • 86 Answers
SOURCE: HTC eris screen is froozen!
Frozen Screen problem mostly occurs when one has recently updated the phone software.
If that's the case with you taking battery out should have helped.
Try resetting it this way.
> Turn the power off. Take the battery off and then re-insert it.
> Hold the Volume Down button
> Hold the Power button until the display turns on
> You are now presented with a menu that allows for Clear Storage.
> Select Clear Storage by pressing the Volume Down button
> Press and release the Power button to select
> Press Volume Up for Confirming your action.
>>> If you selected YES, the phone will reboot to its factory fresh state and would also wipe all 3rd party applications.
Posted on May 25, 2011
diodeic
  • 1622 Answers
SOURCE: I bought htc touch 2 T3320. mobile 7 month before.
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
I hope this will help in solving the problem.....
Posted on Nov 25, 2010
Geekman
  • 32281 Answers
SOURCE: HTC surround keeps restarting...Why? I just
The HTC is faulty, I suggest you return it to the supplier under warranty to get a replacement or repaired. If you try to fix it your self you most likely void your warranty.
Posted on Jun 23, 2011
bryagopan
  • 142 Answers
SOURCE: my htc surround (windows 7
PLease do a hard reset on the phone and here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Posted on Aug 15, 2011
  • 128 Answers
SOURCE: HTC Hero won't charge. I
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Posted on Sep 01, 2011
HTC stuck on HTC screen...wont start
I would try flashing the kernel separately via fastboot and seeing if that helps
Sep 27, 2012 | HTC 7 Surround Cell Phone
I dropped my phone, it was not a hard drop at all! But when i picked it up, it restarted and then i thought everything was good but it restarted again and now it's saying "Storage card not...
Your error indicates that your micro-SD card has been jarred loose or may have gone bad. Check out this link that shows how to remove it. Try taking it out, and booting without it. You can then try adding it back and rebooting. If you get the same error, then get a new card. http://www.tipsopedia.com/how-to-upgrade-the-htc-surround-microsd-card-2-14575/
Sep 13, 2011 | HTC 7 Surround Cell Phone
I just got a htc surround off ebay from someone, box was never opened and phone is brand new.. the phone keeps shutting off even fully charged.. i've even updated it on zune and it still does it. does...
Try a hard reset, and try booting without a SIM if that does not work. If you still have issues, I would go to your carrier or Best Buy and see if they will let you try a battery in store. If the same issue occurs, you could have a bent battery contact, or a completely smoked phone. If you need a new one, ping me at h589221@yahoo.com.
Sep 03, 2011 | HTC 7 Surround Cell Phone
Phone stays on white htc startup screen. have tried removing battery and sim card and restarting
Try toggling the volume bar on the right during boot to see if you get the option for a hard reset. If that fails, you might try letting it run dead at that white screen...probably will take days...then try charging and rebooting. I had an IPOD that resolved by doing that.
Aug 25, 2011 | HTC 7 Surround Cell Phone
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
Aug 04, 2011 | HTC 7 Surround Cell Phone
Whenever I turn my phone on, it goes to the white htc screen and just stays on that for hours until it dies, then I charge it and it does the same thing. I already tried taking the battery out/putting it...
try toggling the volume bar on the right during boot to see if you get option to do a hard reset. If not, try going to your carrier and borrowing another battery in-store to test. If that does not do it, you are probably looking at buying a new phone.
Jul 22, 2011 | HTC 7 Surround Cell Phone
I have hard reset the phone but still its not working. it stuck on the start up screen and restarts after 1 minute
this means you need to change or format your devices memory, because the phone doesn't recognize it any more
Jul 17, 2011 | HTC 7 Surround Cell Phone
My HTC Surround wont power on? Half charged when plugged in, turned off for good about an hour into charge
Have you tried removing the battery? Leave it out for 15 seconds then put it back in and try that.
Mar 08, 2011 | HTC 7 Surround Cell Phone
M HTC surround phone wont start. Its stuck at the HTC opening page. It stays there and wont open up to windows start up and cant get to the menu.
try taking out the battery waiting an hour and then put it back in... Cell phones are like mini-computers and will crash once in awhile
Feb 20, 2011 | HTC 7 Surround Cell Phone
HTC 7 Surround Cell Phone Logo
702 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
