Question about Amana ASD 2624 Side by Side Refrigerator
Neither Freezer nor refrig is cooling
Got home last night to puddle on floor in front of side by side fridge (Amana, ARS2662). Contents of freezer, mainly ice bin, were half melted/thawed. Refrig side contents were also warming. I could hear something running, whether a fan or not, and lights are working, just no cold air. The unit's otherwise run fine in the four years I've had it. Possible suspects: Never knew to clean the coils (underneath). That's probably just for operating efficiency, but could it affect the compressor? Also, seal on fridge side wasn't completely tight though can't imagine that would make a (big) difference, and it wouldn't have been the first time. If not either of those possibilities, have no clue. Haven't explored too much. Did unplug unit on way out door this morning (Will not turning off water cause flood? And should I have opened doors?) What can I check out before paying for a service call and maybe more? Thanks!
  • Anonymous Feb 10, 2008
    fan is on but dont hear compresser
  • detra Oct 13, 2008
    either frezzer cooling, but light is on and barely cool.
  • 87 Answers
Pull the compressor side cover off. Pry off the square box. This is your compressor start relay. Check for continuity. It's probably blown. If ok check for voltage to the compressor.
Posted on Jun 08, 2007
Freezer freezes up. we have made sure that it is not overloaded. when it thaws large puddle of water on floor
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
Refrig side not cooling....freezer side operating fine
Check that the damper vent that sends cold air from the freezer into the fresh food side is not blocked by contents. Check that the damper is opening to allow cool air to transfer. Put the fridge into diagnostic mode to check the thermistors.
Jun 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Referidgerator side is not cooling?? Help?
I had this problem. Here's what I found: The cooling core on the freezer side was froze up. Covered in ice. I think the reason this happened was that the freezer door was held open by one of the slide out trays just enough to pull in outside air. Don't know how long it was like this. When I found it (and corrected it) the interior of the freezer was covered in ice crystals. From then on the refer side contents began warming up. There was no flow of cool air to the refer side from the freezer side (this cool air comes in from the freezer side fan near the top left side of the refer side). Freezer side was near zero temp and the unit ran continuously. Here's what I did: Removed everything from both sides (put it all in another fridge/freezer). Turned off (or unpluged) the fridge and left it off over night. I put towels under the fridge because there can be an over flow of water that could go to the floor. It works great again.
Nov 03, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Amana ASD 2624 Side by Side Refrigerator Logo
258 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
