Question about Ovens
Wall oven turns itself off.
Oven will sometimes turn itself off during use. It will beep once and then stop heating. It will stay off until some one restarts oven.
Other times it will work normally.
  • d_c_davis Jan 18, 2009
    I replaced the power cord and the problem continued. In addition, the display on the oven has now gone blank. The clock read out has disappeared. If you start to set the temperature to bake something, the display shows the bake temperature. The timer has stopped working also and does not appear in the display.
  • d_c_davis Jan 22, 2009
    I have a kitchenaid wall oven-model number KEB11100BWH2. The oven will sometimes, but not always, turn itself off during a baking cycle after it reaches the desired temperature. It will remain off until someone hits bake and resets the temperature desired. The oven will then return to the desired temperature. Sometimes it will continue working normally and sometimes it will turn itself off again.
    In addition, the clock as disappeared from the display although the display continues to show that the oven is baking and what the current temperature is.
    I replaced the power cord and that had no effect.
    Any ideas would be appreciated.
    Thank you.
    Brigadier General:
  • 5,158 Answers
The cooking timer is defective and needs to be replaced.... it "thinks" the time is up to cook and shuts off the oven.
Robert
Posted on Jan 22, 2009
  • 640 Answers
You need to post a model number,,with out looking a a schematic .is all guess work
Posted on Jan 18, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, postback the brand and model and how long the oven has been in service.
Offhand, you may start considering/trying:
  • door switch;
  • loose connection;
  • timer or electronic control board.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Brigadier General:
  • 8,619 Answers
Hi!
Check for the timer like it should not be set to turn off after 5min. or 10 min.
Thanks
Rylee Smith
Posted on Jan 14, 2009
  • Rylee Smith
    Rylee Smith Jan 14, 2009
    There is a problem with the clock which is on the back control panel of the oven, have gone bad due to short. You need to disassemble the oven to look at it and before doing that check out for door latch switch and door switch(might have gone bad due to short circuit).
    Sergeant:
    Scholar:
  • 199 Answers
Check the door hooks and the door-release button. When these are broken,or if the door does not get close  completely  the door switch doesn't activate, so the oven can't work.you will hear a small click when the door get closed completely.
  • Ovens Master
  • 19,396 Answers
Depends on the kind of oven.
Give me exact model number, I do not even know if oven is gas or electric.
    Scholar:
  • 160 Answers
The problem of power cord wire its getting short in between or have a minute cut in it.so giving this problem .needs to be replaced.
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
I have a bosch oven and the power in my house went out during a storm and when it came back my oven started beeping and has not stopped since... what do i do???
Hello- You may have done this already, to save your sanity, but I would turn off the breaker for a few minutes. It is most likely beeping to tell you there was a power failure (as if you didn't notice). Once it is back on you will need to reset the clock, it may not stop beeping until you do this or press cancel. If this does not remedy the beeping there may have been a power surge that caused damage to the control board in which case you should call a Tech out to have a look. Good luck, best regards.
Sep 28, 2010 | Ovens
My GE gas wall oven lights, gets hot, then keeps turning itself off during baking.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 24, 2010 | GE Ovens
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
I am getting a F4 code and beeping. The beeping
Replace the oven temperature sensor. It is located in the back wall of the oven. 4-6 inches long,up high on the right or left side depending on model. Most can be changed from inside the oven rather than through the back.
Sep 02, 2009 | Kenmore Ovens
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
Oven seems to be going crazy
You may have a problem with the keypad. I suggest that you review my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1470 folks and most report success.
If it works for you please let me know at the following site:
hutchipop@yahoo.com
Good Luck
Dec 13, 2007 | GE Profile JKP18 Electric Single Oven
Why does my oven keep switching off?
there is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
Jan 27, 2007 | Zanussi ZDQ895 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
