Question about Kitchen Ranges
-just got stove pluged it in an it will not come on but the light on oven comes on what is wrong ...it will not get hot ontop or bottom
Unplug it then went to circurt breaker plug it back in still only clock and light work
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
This sounds like you are only getting one leg of your power to the stove. The lights will work but that is all. Try reseting the breakers by forcefully shutting both sides of the circuit breaker tied together with a bar or clip. Then forcefully reset them both completly. If your stove still does not work you may want to consult a licensed technician or electrician.
Posted on Dec 03, 2012
  • 213 Answers
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Posted on Nov 21, 2007
SOURCE: Kenmore electric range
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Posted on Sep 25, 2008
SOURCE: Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Posted on Dec 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
How to change oven lamps on Stoves 600EF oven
Well if it is the same as the 720, you will find a small recess in the leading edge of the glass lens/cover. Using a blunt screwdriver, insert it in the slot and twist it. The lens should gradually come away from the side of the oven. DO NOT attempt to do this if the oven has been in use as the lenses will become too hot to handle. Put a cloth on the bottom of the oven to catch the lens as it falls to protect it. Note that there may be a cut out on the inside of the lens to go over the edge of the bulb/bulb holder, so don't try to put the lense back round the wrong way.
Nov 08, 2011 | Stoves 720EF Electric Double Oven
While using the broil function the stove we think got too hot. The beeper alarm sounded and the display window said F2. The cancil button would not shut off the eliment so we pulled the plug. After leting...
This problem is usually associated with a shorted relay on the control board. No...this is NOT normal and there's usually something seriously wrong if you have to unplug a range to turn off any of the features. You will need a new control board to correct the problem. If you want to remove the component leads that plug into the control board broil relay as a TEMPORARY fix while awaiting parts, it can be done, but you need to ensure its done correctly. Follow these steps:
1. UNPLUG the range and turn the appliance around so you can access the back panel.
2. Remove the back panel so you can view the control board and wires leading to the broil relay.
3. Disconnect the wires from the CONTROL BOARD and tuck them away where they will not be in contact with any heat source or electrical source.
This will render the broil function inoperative and takes the least amount of time. Since the broil element is working, I wouldn't recommend removing it. This will save you the time of possibly damaging it and/or having to reinstall it later.
NOTE: Some ranges use the broil element during the BAKE cycle to preheat the oven. If your range is designed this way, you may or may not have desired baking results.
The surface elements/burners work independently of the oven, so they should still function normally.
Replacements parts can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Take the time to repair the appliance and do not leave it configured this way as a permanent solution. Some websites (Sears) will sometimes offer the refurbished control boards at a fraction of the price if a brand new one exceeds a price you're willing to spend.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 27, 2011 | Kitchen Ranges
How to change oven coil
Unplug the stove. Be sure to kill power to the oven because one wire to the element is hot and comes straight off L2 the power cord. You could seriously injure yourself or destroy the new part by leaving the range plugged in while you replace this element. Tip: pull out the bottom drawer and you will be able to see the power cord and receptacle in most cases and you can unplug the stove without having to move it. When you have the power removed you only need to remove 2 screws and gently pull the element towards you have the new element sitting on the oven so you can add a wire to it as you remove it from the old one so you won't loose a wire through the back. That is how I do it.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Bottom oven will not come on
is it the oven or the stove top
what make ie ge ,lg??
how old?
does it use elements or ??
Jan 02, 2009 | Thermador C302U Electric Double Oven
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
