Water leak AWG 5061/M/600 RPM
    Sergeant:
  • 198 Answers
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%
Posted on Dec 02, 2012
My car idles at 1000 rpm
Usually when this happens its a Vacuum leak causing it. Try using a spray bottle of water around the seams of the engine while the engine runs. any leak will pull in the water and change the rpm or stall the motor.
Depending on what you find, it may just take some gaskets.
Feb 21, 2013 | 1991 Ford Explorer
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
Need user manual for whirlpool AWG 5061/M --600RPM AA 5Kg
I NEED USER MANUAL BOOK FOR WHIRLPOOL FRONT LOAD W/ MACHINE MODELS NO AWG-5061/M AA 5KG 800 RPM please send it to me on fayaz_1966@yahoo.com I will be greatful to you Thanks
Nov 03, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Give the allowable number of wire for each conduit sized listed below. size wire 15mm(1/2) 20mm(3/4) 25mm(1 inch) No. 2.0mm(No.14 AWG) No. 3.5mm(No 12 AWG) No....
The fill would depend on the wire type because the type of insulation determines teh circular mills of the conductor here are some examples though of THHN,THWN,THWN-2 wire.
Based on NEC2008 Annex TableC.1
1/2" (16mm)conduit=12-#14THHN,9-#12THHN,5-#10THHN,3-#8THHN,2-#6THHN
3/4" (21mm) conduit=22-#14THHN,16-#12THHN,10-#10THHN,6-#8THHN,4-#6THHN
1" (27mm) conduit-=35-#14THHN,26-#12THHN,16-#10THHN,9-#8,7-#6THHN
Aug 18, 2010 | Gb Electrical 1 30 Amp Ground Fault...
Brakes go to the floor and the car run rough with...
Sounds like the Brake booster. There is also a valve on the vacuum line going to the booster. Its plastic and can crack and leak.
You can do a water spray test with a pump bottle. Spray the brake booster while the engine runs, spray the vacuum lines and the fittings. When the water is drawn into the engine it will change RPM or stall. The leak is where you sprayed to make the RPM change.
You will need to replace the defective part.
May 17, 2010 | Cars & Trucks
Hi I have an AWG 329 washer drier. The water won't
the pump is either broken or there is a block in the drain line sadly with these ne high tech units they can break down within weeks ive seen 3000 dollar washers and fridges writen off as quality test are very weak
Apr 21, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
10/3 or 12/3
Nozzle,
AWG Ampacity from table 450-5b of the National Electric code states the maximum ampacity;
12 AWG = 20 Amps
10 AWG = 30 Amps
8 AWG - 80 Amps
According to this, an electrician would pull 10/3 (or 8/3) for a dryer service because 12/3 is not allowed (by LAW) for this application.
Hope this helped,
SG
Apr 06, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool AWG 354: Water flowing can not stop
Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
Dec 19, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
