Question about ViewSonic E50 15" CRT Monitor
Cannot st maximum refresh rat
My monitor is ViewSonic e50cb (Asian model) the maximum refresh it supports according to the product specifications is 67Hz at 1024x786 resolution. but in the settings in windows xp the maximum refresh value shown is 60hz. My question is how do I set my monitor refresh rate to 67hz as specified in the product specification? Good Luck Julian Leonardo
  • Julian Leonardo Jun 07, 2007
    well i did download drivers the list of monitors available in the .inf file was e50c although my moniter is e50cb. but i still have the problem
  • Anonymous Sep 06, 2008
    I HAVE A VIEWSONIC MONITOR E50 AND IN THE DEVICE MANAGER THERE IS A YELLOW ? MARK..HOW DO I PROCEED.PLS HELP
  • 64 Answers
Usually you can only change the device options if windows XP recognizes the device. Does it show up as a viewsonic E50cb in Device manager (My computer, Properties, Device Manager) or just as Plug and Play monitor? I would download the drivers (or if you have the CD) for the specific monitor you have and then I bet the options will open up for you the way they should be.
Posted on Jun 07, 2007
SOURCE:
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
What should the display rate be set at for a Viewsonic VG910s. The default is 60 MHz - can it be changed to 72 MHz?
The default is 60Hz (60 cycle, not 60MHz (60 million cycle) for Vertical refreshing rate.
From user manual:
"For the best picture quality set your LCD display timing mode to:
VESA 1280 x 1024 @ 60Hz. "
and here is the warning:
"WARNING: Do not set the graphics card in your computer to exceed the maximum refresh rate of 75Hz; doing so may result in permanent damage to your LCD display."
http://www.viewsoniceurope.com/uk/support/downloads/user-guides/?keyword=VG910&x=17&y=5
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2010 | ViewSonic VG910 (Black) 19" LCD Monitor
View Sonic Monitor Serial No. QQ2081640466 Model No. VS11826 please let me know warranty of this monitor
Hi u3salkar, What the warranty covers:ViewSonic warrants its products to be free from defects in material and workmanship during the warranty period. If a product proves to be defective in material or workmanship during the warranty period, ViewSonic will, at its sole option, repair or replace the product with a similar product. Replacement Product or parts may include remanufactured or refurbished parts or components. The replacement unit will be covered by the balance of the time remaining on the customer's original limited warranty. ViewSonic provides no warranty for the third-party software included with the product or installed by the customer. Check this link ....http://www.viewsonic.com/support/warranties/limited-warranty/
Hope it may helps:
Regards; VOTIT
Dec 03, 2010 | ViewSonic VA1716w Monitor
I havE A VEIWSONIC Va520 when I turn it on , it brings up a screen saying out of range H-30-62 KHZ V-50-75 Hz what does this mean?
1. maybe the problem is with windows, because the refresh rate is set to an acceptable value
2. your lcd screen runs at higher hz than 60
3. you are running a resolution higher than 1024x768 15" LCD's generally can only support 1024x768 whereas larger panels support higher resolutions.
Possible solutions
1. The LCD you buy is shipped with a plastic cover over the screen which shows maximum resolution and recommended refresh rate. When you first turn on your computer press F8 to access safe mode, after you enter safe mode, configured the required setting on your lcd monitor. when you are done, reboot or restart your computer, hopefully your computer should be fine.
2. attempt to access the bios setup utility by pressing del or f2 of your keyboard after you see the initial display of your pc, if you can see it, the problem is with windows because the refresh rate is set to an acceptable value. Set it to its required settings by entering safe mode as posted on no.1
http://lcdmonitor-repairsecrets.url-Go.com
Dec 02, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Refresh rate for this monitor. Prefs. offer 60 or
Go for the highest your video card will allow to remove any flicker from the screen, or the max whichever works best.
I also have a Viewsonic Flatscreen, they are great and I had two Viewsonic CRTs before that.
Nov 28, 2009 | ViewSonic VA702b 17" LCD Monitor
OSd lock keeps on poping up on my screen
check your vga/dvi cable connection at both ends, computer and monitor
Nov 01, 2009 | ViewSonic E70f 17" CRT Monitor
How do I install it? It was donated. No instructions.
Plug it in to your PC/laptop. Windows should recognise it and assign it basic drivers. Go into Control Panel, Display to change the resolution and refresh rate to what you want. No real need for manufacturer specific drivers but you can probably download them from viewsonic if you want.
Sep 11, 2009 | ViewSonic VG181b 18.1" LCD Monitor
Digital Repop
Hi, Even if it is refreshing, shouldn't be that noticeable. One possible reason is not enough memory in your video card for which you can try compensate by increasing the Graphics Aperture Size in your CMOS/BIOS setup. Normally it should be twice of your on-board/add-on video card memory. Another possibility is your LCD monitor is showing signs of pending problem which could either be the CCFLamp, the inverter that powers it or the video interface. Some models of Viewsonic are known to have inverter failures. Specifically, the capacitors are overheating and would need replacement. In some instances, it is the lamp that goes or still others are simply cold solder joints. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | ViewSonic VG2230WM LCD Monitor
ViewSonic E50 15" CRT Monitor Logo
133 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
